Question about Dell Optiplex GX110 (2909T) Motherboard
Motherboard problem the orange light on the LAN port comes up anytime i connect the system to power and the system does not power on
  • hariharihari Apr 09, 2009
    I cannot enter the setup utility. when I press the F2 button, the computer hangs for a long time then appears message "Invalid configuration. Please run setup". But i cannot run setup.
  • 60 Answers
If you have another power supply around or can borrow one try it.
Posted on Sep 22, 2008
Wt8951nd
Power cord
RJ-11 telephone cable coming from a splitter or the extn. line of your landline phone.
Ethernet cable coming from your Desktop/Laptop connecting RJ-45 port
Most standard ADSL modems have four/five lights in the front :
Power light to indicate electric power to the modem.
ADSL light indicates the status of ADSL sync. When the modem is synchronized with the ADSL line card at the other end of the circuit/loop, the DSL light will be steady green.
LAN light will glow steady green when the modem detects a successful link to a computer or router ethernet port.
ACT i.c. Activity light glows when the modem is sending and/or receiving data on the lan and wan. It will vary between very slow to fast flashing and steady green to indicate lan/wan traffic.
for more help visit CBR Tech Solutions
Feb 08, 2014 | Computers & Internet
Network fails through one port going orange
The ASUS site has a quick start guide (I read Version 3) that says the lights show blue for connections and blink blue for activity. Sometimes orange indicates a connection at a lower speed. What happens when you try a spare port? What is connected to the 'orange' port? What do the lights at the other end of the suspect patch cable indicate? Note that the manual isn't great because the titles say Gigabit Ethernet but the text talks about 10/100 but not 1000 megabit ethernet.
This is a layer 2 device and it ain't exactly the cleverest box on the LAN. If you move devices to other ports, it is supposed to figure that out dynamically. You should be able to eliminate devices one at a time to determine which port or device is defective. Start by eliminating the 'orange' device. If the router is disconnected can you still print?
If you have limited functionality with the suspect device disconnected, the problem could be with that device. Sometimes cables can be a problem. Not likely but it is necessary to check by substituting a known good cable on a link. If the problem goes away, it was the cable.
Remember to photograph the initial configuration with your smartphone. That can help you when you forget where you started. Label the wires with masking tape if there are no other labels, so you can find your way back to the starting point.
Nov 01, 2013 | ASUS GXD1081 Ethernet Switch 8 Port 8 x...
The Ethernet port of my Asus M4a77td motherboard stopped working. I think it is a hardware problem because when I plug the router cable on the port, the corresponding light on the router does not turn on...
Yeah, the link light on the router should be coming on.
A few simple things to try:
Try a different network cable. Try a different port on the router. Visually inspect the port on the system and router to confirm they are not physically damaged in any way.
Feb 28, 2011 | ASUS M4A77TD Pro Motherboard AM3 AMD 770...
Cant connect to the enternet.asus sabertooth motherboard.i show an orange light at mobo conection
sounds like you need the lan driver go here and look up your motherboard and download the drivers. http://support.asus.com/download/download.aspx?SLanguage=en-us If this doesn't work you may need a new lan card.
Jan 06, 2011 | ASUS Sabertooth X58 LGA 1366 Intel X58...
Computer cant find a lan port
check device manager if ethernet adapter is installed or not installed. for this you type 'devmgmt.msc' on run.If ethernet adapter is not installed you can use your motherboard driver cd for installation of drivers
Jun 22, 2010 | E-Machines T6420 PC Desktop
Connecting inteface with computer- lan port
The LAN (or Network port) is located on the back of the motherboard. When you connect the cable from the AR 161 to the motherboard, the lights will start to flash - Green = Stable and Orrange = data flashing.
Sep 23, 2009 | Sharp AR-161 Laser Printer
Lan connection!
is the lan port on the motherboard?
if yes, is the lan port turned on in the BIOS?
Does XP detect the port?
If no, check if BIOS setting is on.
May 17, 2009 | HP Vectra VL400 P3 Skt 370 Motherboard...
The internet cable port cant dettect connectivity
Check your DNS settings after replacing the LAN chord....sodeep
May 04, 2009 | ASUS Computers & Internet
2 Lan ports not picking up cables
Try to uninstall and reinstall the driver for the LAN cards. You can also try to remove it from the motherboard, change PCI slots then reload the driver.
Jan 12, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Dell Optiplex GX110 (2909T) Motherboard Logo
110 people viewed this question
Alun Cox
