Question about Cameras
ERROR 99 HI I have TAMRON 18-200 LENS which fixes to my canon DSLR CAMERA from past few days when i connect this lens to camera the display shows error 99 i have even canon lens from that working ok .i know the technical problem is in my lens pls guide how can i repair this . regards raghav I am also facing the same problem with my Tamron 70-300mm f/4-5.6 Di LD MACRO 1:2. I did cleaned the lens connection but after few shot the same problem appeared again, I am so disappointed. Causing me unable to a decisive moment picture. Arggggggggggggg.... Regards steve
I am having a similar problem with my Canon 20D. Today I narrowed it down some. It does not appear to be a camera problem, it appears to be a lens problem. My Canon EF-S 17-85mm lens seems to be having all the problems, but when I change to my other lens everything is fine. That lens has gotten worse, to the point where today I was almost unable to use it at all. Wide angle shots only!
So I hope that helps. Now to figure out what's wrong with my lens and how to get it repaired...
Posted on Apr 23, 2009
I have faced similar problems previously with my Canon 20d and Sigma 170-500. Its even more annoying to see it happen in field while it would be okay back home. I was told that it is electronic compatibility problem instead of complaining the best was to change the lens and hence bought a 100-400 and happy ending.
Posted on Sep 29, 2008
Error 99 with a Canon 300D (original rebel) and Tamron XR Di II 18 to 200 mm lens. Occurs when lens is zoomed out. Does not happen with other lenses (Canon 18-55 kit, Canon 75-300). Cleaning contacts on...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
Apr 17, 2011 | Tamron AF 28-200mm f/3.8-5.6 LD Aspherical...
My tamron 28-75 f2.8 canon mount is not working. It focuses but errors when I hit the shutter. help please. thanks
What error number is shown? If Error 99, this article will guide you through identifying the problem and possible fix.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 14, 2010 | Tamron 28-75 F2.8 XR AF Lens
Canon 30d with tamron af 70-300mm di macro lense showing error 99
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable. Alternately, it can also be a card error or camera error.
First remove the lens, battery and card and leave the camera like that for about 30 min. After that, insert a fully charged battery and switch on the camera. If the error still shows up, it is a fault with the camera and has to be serviced.
If not, turn the camera off and insert the card. Format the card in the camera and depress the shutter button. If it shows an error, the card is faulty.
If not,
try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting.
If the error still shows up, you need to take the lens to an authorized service center.
Jul 12, 2010 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Error 01 tamron lens 70-300 mm af 4-5.6 with canon dslr 450d
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
May 28, 2010 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
My Canon 400D camera keeps coming up with error 99 I have cleaned the contacts on both my camera and my Tamron 28-200 lens.At first i thought it was my camera but I tried it with another lens and it...
Hi turn on the camera with the lens on set to tv and a iris of f22 and use the stopdown button if the lens stops down the lens is ok if not the lens is faulty may need a intuper replaced
Jan 11, 2010 | Tamron 28-200mm F3.8-5.6 for EOS
Err 99 with canon 350d
This error may be displayed if you use a non-Canon lens and the camera or the lens does not operate properly. Remove the battery and re-install it. If the problem persists, get your camera / lens checked by a qualified technician.
Hope this works. Thanks.
Jul 14, 2009 | Tamron AF70-300mm f/4-5.6 Di LD Lens
ERROR 99
try cleaning the lens contacts of your lens and camera.
Jul 31, 2008 | Tamron 18-200mm f/3.5-6.3 for Nikon
AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Nov 04, 2006 | Tamron Zoom Telephoto AF 70-300mm...
Error 99 in my Canon 300D
You're probably right about the lens. Tamron lenses have a flexible circuit that drives the aperture blades. The aperture might need to be cleaned or the flex might be worn out. Either case needs a repair shop to correct.
Nov 04, 2006 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
391 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
