1996 Lincoln Town Car Logo
Posted on Sep 22, 2008
1996 licoln towncar gear selector
The gear shift selector will go into reverse and then it will only go into drive after a few tries. It's like it got rotated to the right and won't go into 1st or second manually
  • musclecar Nov 23, 2008
    can I buy this items at any Auto Part Store? Do I ask for gear selector - is this what some call The Brake Release sensor?
    Thanks
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
319
Points
MY LINCOLN WOULDN'T GO INTO ANY GEAR.I WAS STRANDED I CALLED THE FORD PLACE,THEY SAID ON THE BRAKE PEDAL UPWARD THERES A LEVER.A CHILD SAFTY THING.THEY SAID PUSH UP ON IT I DID AND IT WORKED.IT HAPPEN AGAIN BEFORE WE GOT IT FIXED,AND I PUSHES ON IT AND IT WORKED.MY HUSBAND REPLACED IT FOR AROUND 10 DOLLARS.HOPE THIS HELPS
Trouble shifting into 2nd gear and reverse but drives good once it shifts?
No not the whole transmission. Could be a band or servo. It still has to come out and be tore down to fix.
2answers
Why do I have reverse gear but no reverse lights? Light worked recently, and not bad bulbs or anything, what could it be? I have a 1996 gmc jimmy sls 2wd automatic. Thank you
Does you shift indicator point to "R" when in reverse. The reverse light are switched on by the selector shaft position sensor built into the Parp/Neutral Safety Switch. It may be bad or just out of adjustment.
Reverse not working
It sounds like a gear shift alignment switch/linkage...Try your mechanic before a transmission shop. Should be less costly, and only address the alignment of the selector.
I have a problem with my shift gears, in order for me to drive (D) I have to put in on 1 or 2, to reverse (R) I have to put in on (D) drive, to park (P) I have to put it on reverse (R). Tell me what's
sounds like the cable from the gear stick to the gearbox selector switch has been put on wrong ,put the car into reverse so that the reverse light is on , turn the ignition off and find the gear selector on the gearbox , pop the end of the cable off it then put the gearstick into the "R" position and refit the end of the cable back onto the selector switch , hope this helps
1996 Jeep Grand Cherokee. Transmission problems. when the gear selector is in reverse, it doesn't engage in reverse. When you go to neutral, it drives forward but doesn't shift through the...
Put the vehicle in Park, disconnect the shifter from the shift lever on the trans, adjust the linkage or cable so the connection is clearly a slip in/on connection and tighten things back up. Hopefully this will solve your non-reverse. As for all the gunk and metal shavings, friend, you better have another tranny standing by in your garage when this one stops working completely.
1996 dodge ram 1500 4WD shifts into reverse fine starts off in 1st and will not shift into 2nd gear
Could be as simple as low transmission fluid, but it can also be your shift solenoids or gonked up valve body. Star with checking your transmission fluid level. On that vehicle its pretty simple. There should be a yellow dipstick. Vehicle needs to be on and on operating temperature. Gear selector in P or N. Pull the dipstick out and see what it reads.
MY MERCEDES BENZ C200 OF 1996 CANNOT MOVE INFRONT IT CAN ONLY REVERSE WHAT COULD BE THE PROBLEM?
I assume the car is automatic transmission ? Can you select a lower gear manually using the selector ? Also with the engine running, parking brake firmly applied and the car in Drive, check the automatic transmission fluid is at the correct level. The dipstick is not present on some models however, which is a pain, and would require a dealer visit. If the stick IS present, its on the left side rear when viewed from the front of the car, make sure the fluid is between the two marks.
If your cars is manual/stick shift and it drives in reverse normally, but not in any forward gears then you have a selector issue or internal gearbox failure.
Transmission shifting problems
If Drive Selector switch is properly aligned then a shift silonoid might be the problem.
1996 Audi A4 2.8L will not shift into reverse or park
You need a new inhibitor switch on the gear selector.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
