Question about HP mx705 17" CRT Monitor
My monitor turns yellow
My monitors turns yellow, I'd already move the cables and its still yellow,
  • 2,992 Answers
Computer monitors get separate red, green and blue video signals from the computer, and if you lose the blue the result is a yellow picture. This can be caused by video card failure in the computer (very unlikely), a bad cable (fairly common), or trouble in the monitor (which is most likely what you have).
The usual problem with monitors is bad solder connections to the red, green and blue output devices. These are usually three separate transistors, but sometimes an integrated circuit that puts all three in one package is used. These outputs get pretty hot, and the heat can cause the connections on the circuit board to crack. Resoldering them usually fixes the trouble. (Sometimes the part actually fails, but bad connections are more common.)
The parts are normally in one of two places. Most commonly they are on the small circuit board you'll find right at the neck of the picture tube. Some monitors have them on the main circuit board. They may be mounted to metal heat sinks to help keep them cool. If you can identify them and resolder the connections, you'll probably get your normal picture back.
Posted on Nov 19, 2008
    New Friend:
Wow! thanks u r right!
Posted on Mar 05, 2013
A photo of a yellow car is pink
The discoloration indicates you are missing one of the three color bands (magenta, cyan and yellow). Likely the display cable from your computer to monitor has a slight break in one of the interior wires.
Slowly move the cable around near the connectors and observe the picture. If you see it change, replace the cable. You can get one from any computer store for about $10-$15.
Aug 26, 2013 | ViewSonic VX1935wm LCD Monitor
It tuns green and when you turn on computer it turns yellow and then a light yellow and will not come on
Your monitor cable may be bad. This happens. Try a different cable.
If not, try a different monitor to ensure the computer is displaying. Also make sure everything is plugged in firmly (not HARSHly, just tight).
Also, try testing the monitor with a laptop. This will eliminate whether the monitor is shot.
Feb 28, 2011 | Westinghouse L1975NW Monitor
My monitor keeps turning yellow constantly. How do i fix this problem?
-check the monitor cable (vga cable the one with blue connector) for broken pins
-if there are broken pins replace the cable
-if not try another monitor cable or try the monitor to another cable
-if the monitor still turns to yellow after trying another cable or connecting it to another computer to problem could be with the monitor or the vga card
Nov 24, 2010 | Computers & Internet
Only says cable disconnected on screen
May be your monitor cable has been faulty.You can check it from service center.
Mar 24, 2010 | Dell E551 15" CRT Monitor
My samtron monitor turned into yellow colour
Sir this usually happens because of Serial cable getting damaged I have been through same problem have took my monitor every where but was no use in the end I thought of changin monitor serial cable and now its working great. So I would recommed you to change serial cable.
Nov 11, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
My Sony Moniter suddenly turned to a bright yellow
If the display looks normal other than being yellow, it's missing blue.
This may be because of a bad cable. Sometimes the wires inside break from flexing. Try wiggling the cable (as mikeslab suggested) at the end where it connects to the computer. Also check the plug for bent pins.
It's more likely the monitor has lost blue due to solder connections to the blue output transistor or transistor failure, or that the picture tube itself has gone bad and the blue gun has quit. Tube failure is pretty rare. I've seen many cases of bad connections and transistors, though.
If the cable and plug aren't the cause, you can have a service shop check the monitor and give a repair estimate. But if this is a 17- or 19-inch monitor, you might just want to replace it. New LCD's are $150 or less. To repair yours would be around half that cost already, possibly more depending on labor and parts costs.
Apr 24, 2009 | Sony Computers & Internet
Check the video cable at both ends to make sure it is connected properly.
Move the cable around near the ends and chances are it will look normal. If so then you have a broken wire inside the video cable. A common thing and easy to get another cable.
Apr 03, 2008 | Mag Innovision LT776s 17" LCD Monitor
Audiobahn AVM270Q (white out)
You have to check if Video cable from Flip Down Monitor has RCA Plug Cable or Super VHS Plug Cable.
RCA Plug is Yellow for Video= connected to Yellow Input of radio maybe loose.
Get VCR or Video Camera and connect Video Output with cable to Yellow RCA Plug of Flip Down Monitor.
Turn car on and VCR/Video Camera: you should get video to FL Monitor.
If not, then FLM is defective or has adjustment problems..
Mar 07, 2008 | AudioBahn AVM270Q 7in Widescreen Car...
Yellow dispkay
the display turns to yellow when the blue colour is missed form cable. check the vga cable or may be it's from inside monitor. from the vga card. check the cable first then call or mail....
Feb 22, 2008 | Microtek C893 18.1" Flat Panel LCD Monitor
HP mx705 17" CRT Monitor Logo
3,542 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
