My HP pavilion ze 4900 notebook became very very slow over night. It has 256 ram. will extra ram fix it? It runs hot. did the fan quit?
  • 60 Answers
Do you have a program that removes spyware and adware.Also what operating system do you have? More ram will speed it up.An easy way to see how much you can install would be to go to crucial.com just to get an idea of what you can do with it.You need to defragment your drive also.If you have not defraged your pc,it will cause it to slow down also and even stop working altogether.I haved used spywaredoctor for the last 4 years and it has proven itself to me.Hope this helps.Goodluck.
Posted on Sep 22, 2008
Describe your HP HP Pavilion dv5-1150us Notebook Laptop PC It gets hot, especially the built in mouse. Should I vacum the vents/
Laptops do tend to get quite hot but cleaning it at least once a year should help. You could vacuum the vents but it usually works better with compressed air. You can also buy small docks for laptops that have extra fans on the bottom to help cool.
Chris
Aug 13, 2011 | HP Pavilion dv6000z Notebook
I have an hp pavilion ze 4900. I need to get into Bios memory options to disable caching or shodowing so I can go into safe mode.
Press and hold both "delete and F8" rapidly while you PC boots this will then take you to the bios screen. Save changes then exit.
Sep 01, 2010 | Computers & Internet
My hp pavilion ze 2000 shows no display, not even on an external monitor. is there anything that can be done rather than replacing the motherboard?
Hi!
The problem can be anything it can be the ram or graphics card etc..to confirm the problem please remove the ram clean the copper contacts of the ram with pencil eraser then reseat them if the problem persist then replace the ram.
Aug 27, 2010 | HP Pavilion ze2000 Notebook
My HP Pavilion DV2000 working very slow, heating too much Please suggest
check that the fan is working, go for hard ware check , run registry cleaner reg in out
Aug 27, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How do you fix the disc drive In the hp pavilion ze 4900
it has some kinda side block...take a look how the hard drive is locked in..
Jun 21, 2010 | Computers & Internet
Hp pavillon is roasting hot fan working but not cooling any ideas
Put something between the table and the notebook PC so that there is some ventilation. This might cool down the notebook. That is what I do for my Thoshiba laptop. Another option is you can buy something that is made specifically for this purpose. It is a small square shaped plastic sheet like thing which as a few small fans in it. The fan takes it power from usb port. The whole thing is about 7or 8(maybe even lesser) mm thick. Price around $20. Or else buy the smallest fan that runs on 110v (if your normal power is 110V AC) you can get and put it behind the notebook facing outwards. Idea is to exhaust the hot air from the surrounding of the notebook.
Oct 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Display freeze then colors became crazy
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 10, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP ze 4900
check on the device manager , if the driver for wifi are installed or not , if installed then , press the Fn key alongwith the Key that marked wifi mark on your laptop
Nov 06, 2008 | HP Pavilion dv4000 Notebook
Ac adapter for hp pavilion ze 4900
Go to spare parts shop you can resolve your problam with min price
Jun 13, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
CTX Optoma EzPro 580
Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
Aug 11, 2007 | CTX Optoma EzPro 580 Multimedia Projector
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
