Question about Dryers
How to attach a 4 prong plug to a dryer - Dryers
    Novelist:
  • 177 Answers
Read your owners manual. they should have a section on what to disconnect and where to connect
Posted on Sep 23, 2008
How to change a 3 prong plug to a 4 prong plug on a frigidaire gallery electric dryer
where the green ground was attached to the body it will now be attached to the middle prong? u can use youtube to see how to go from 3 prong to 4 prong if this is confusing
Jun 10, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Three prong to 4 prong outlet
Yes it can be. I suggest you get a licensed electrician to handle it.
Jan 27, 2013 | Bosch Nexxt 500 Dryer
Just moved into an older home with a 3 prong dryer receptacle. My whirlpool duet dryer model: GEW9250PL1 currently has a 4 prong cord. I have purchased the 3 prong cord and am ready to install. Very...
Hi, White, green green/white striped they are all the same....only thing you really have to worry about is that you have the red and black in the proper places...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 13, 2011 | Dryers
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
Feb 04, 2011 | Maytag Dryers
Connection
the green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
Feb 23, 2009 | Dryers
4 prong to 3 prong
connect green wire back to cabinet rear at green screw..in a 4 wire hookup the green wire from the dryer was supposed to be either cut off or attached back to neutral(center screw)
Oct 24, 2008 | Roper REX4634KQ Electric Dryer
I am trying tochange my
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similar with one exception. The 4-wire plug uses an additional (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope this helps you.
Feb 29, 2008 | Dryers
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Dryers Logo
66 people viewed this question
Top Dryers Experts
