Question about Dacor ECD230 Epicure Stainless Steel Electric Double Oven
Dacor double oven
My dacor double oven is flashing and beeping prb on the control panel. It does this when the oven is on and off. What does this mean?
  • jkphil Oct 26, 2008
    Hey, my Dacor Millenium stove has just started doing the same thing.  Help!!!!  What does it mean?
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Posted on Nov 20, 2008
vitg55
  • 78 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
localwonder
  • 6784 Answers
SOURCE: Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
Posted on May 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: oven beeping
yOU NEED TO CHECK THE FAULT CODE F1 MOST LIKELY THIS IS A STUCK BUTTON . HERE IS THE DACOR MANUAL
Posted on Aug 21, 2009
  • 3 Answers
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Posted on Nov 27, 2009
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
May 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
My oven flashes and beeps F 4. What does it mean?
F4 on a Dacor oven is a bad temperature sensor.
The temperature sensor is inside the oven up high on the back wall
Mar 29, 2011 | Dacor PCS130 Preference Electric Single...
I have a Dacor double oven that gives a error message of F0 and then shuts itself off.I don't have the manual so I don't know what this error code means or how to fix it.HELP!
F0 means shorted keypad or stuck key on keypad.
Solution: The membrane aka keypad has to be replaced.
There's a slight chance that the ERC aka oven controller is acting up also.
So safest bet replace both, ERC and membrane.
Dec 24, 2010 | Dacor ECD227 Epicure Electric Double Oven
Prb flashes on the control panel
http://www.google.co.in/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Flib.store.yahoo.net%2Flib%2Fusappliance%2Fwalloven-manual.pdf&ei=j0mISrCgM8iOkAWFy5ihBw&usg=AFQjCNFa_wAnlQ4ip23MwFztIYTXiyDC8Q&sig2=7gUbH8QmlLQ-PASP5zxJZQ
Hope this helps.. Please rate me!!
Aug 16, 2009 | Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Oven constantly beeping
PRB refers to the power relay board.It is not an error message.Probably the PRB is damaged and needs a replacement.All the best.And please do comment as to how else i can help you.
Jan 15, 2009 | Ovens
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Jun 29, 2008 | Ovens
Dacor ECD230 Epicure Stainless Steel Electric Double Oven Logo
76 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
