Question about E-Machines eMachines Desktop PC
Pc powers up but nothing on the monitor
I have a gateway T6536 emachiane that has a K8NGM2 H Motherboard when I turn it on it powers up I can hear the fan but nothing shows on the monitor
  • Bill McDonald Sep 22, 2008
    I appreciate yer comment, I also heard it could be the Battery in the Motherboard , plus the memory there are 4 slots 2 blue and 2 green if I'am correct 2 are for DDR ram
    Problem Solver:
  • 11 Answers
If the fans are blowing, then the power supply is good. If you don't get anything on your monitor at all from the get go, then it NOT windows.
Don't mean to downplay this problem, but have you checked the physical connections on your monitor? Try another monitor if possible. If the other monitor does not work then you know for sure it's the motherboard.
Posted on Sep 22, 2008
  • 60 Answers
I have run into this a few times and it has turned out to be a bad motherboard.Also the power supply they put in the emachine is not very good.The power supply in them has caused the motherboard to blow.Im not saying it is your motherboard, that is just a good possibility.Goodluck
  • Mike Sep 22, 2008
    yes sometimes it could be the cmos battery.As for the memory it sounds to me like you have dual channel memory slots which are all DDR or could be DDR 2
I have a Gateway M 1625 laptop. When I power it on the blue light is on for power and I can hear the fan turn on, but nothing shows up in the screen. Replaced the hard drive and still nothing. I hooked...
This indicates a motherboard issue, remove main battery and test, if no change! remove the ram memory one at a time and test each, if no result! it is time to get a professional in to assess.
Apr 17, 2012 | Gateway Computers & Internet
MS-7207 K8NGM2-H MOTHERBOARD Model:K8NGM2 -H E machines T6528 no video will display tried PCI -express video card and still no display. Monitor tested on other pc and works fine
If you are using a PCI-e video card, you will need to install a driver. If you have onboard video on your motherboard and that isn't working, I would say that your motherboard is fried and you need a new one or a new machine.
Jul 18, 2010 | E-Machines Computers & Internet
GATEWAY E4000 Desktop P4 1.8GHz ,768MB doesn't recognize monitor
Try pulling the ram chips out and see if it turns on.
pull out the cards and unplug the cd and hard drive and see if it turns on,,
If you have no luck then its a bad cpu or motherboard,
Apr 10, 2010 | Computers & Internet
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
Motherboard
Unplug all peripherals (hdd, dvd etc) so only the M/B, power supply and monitor are connected.
If you still have the problem then you should suspect there is a fault with(in this order) the power supply, M/B then the CPU. My bet is on the power supply.
Best of Irish Luck to yer.
Sep 16, 2009 | ASUS A8N-SLI Motherboard
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Feb 18, 2008 | Intel Motherboard
MSI 7207 Motherboard (K8NGM2-L)
http://global.msi.com.tw/index.php?func=proddesc&prod_no=245&maincat_no=1&cat2_no=&cat3_no=
here it is...from here you ll take the manual,the configuration,the drivers and all the rest about your board..
fixya man:)
bye bye
Feb 09, 2008 | MSI K8NGM2-NBP Motherboard
K8NGM2 Mother Wont Power Up
I've seen situations similar to yours several times and they've always been a bad CPU.  Since you tried a new video card it's not that, I would suggest a new CPU.  Check on ebay, you can usually find used one's on there.
Oct 10, 2007 | ASUS A8N-SLI Motherboard
E-Machines eMachines Desktop PC Logo
136 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
