Question about Onkyo Audio Players & Recorders
Have an onkyo TA-W202 dual cassette deck that I've moved many times. Just removed it from a stack so unplugged & moved. I've since plugged it back in and all the motors seem to work fine yet it no longer seems to "see" when playing - ie the little equalizer lights don't show and there's no sound. True for both decks, multiple tapes. Did something loosen?
PROBABLY THE CARBURETOR NEEDS ADJUSTING OR THE JOHNSON ROD IS OUT OF ALIGNMENT.. AND POSSIBLY THERE COULD BE A HOSMATIC DILDONIC ERROR THAT MAY BE THE PROBLEM.. AT ANY RATE I THINK WHAT YOU NEED TO DO IS TO POUR VINEGAR SAUCE ON THE GRID AND CLAP YOUR HANS REALLY HARD 4 TIMES AND SHOUT "HALLEJUHAH"..
Posted on Oct 23, 2011
Wiggled a wire and it started working again
Posted on Sep 23, 2008
TA-RW255 DUAL CASSETTE DECK
Have you check and make sure that the belts are working well?
Is the pinch roller working (spinning)?
A worn out belt will make the mechanism not to operate properly resulting in shutdown to avoid damage to the tapes.
Apr 11, 2008 | Audio Players & Recorders
ONKYO TA RW11
This would indicate a belt problem as far as the Capstan system goes.
This would need to be worked on by a person who can do a belt change and oil the appropriate bearings.
Feb 18, 2013 | Onkyo Audio Players & Recorders
Where can I find a repair manual to replace belts on my Onkyo Stereo Cassette Tape Deck TA-630d
I have found a service manual for you that can be downloaded free:
http://elektrotanya.com/onkyo_ta-630m-sm-tape-deck.pdf/download.html
After the page is appeared fully, click on this place:
Get Manual
Not logged in
Only 2 downloads
allowed a day
and the downloading will begin.
gylacz
Mar 31, 2011 | Onkyo TA-RW255 Single Cassette Deck
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
My cassette deck Onkyo model Ta 2060 is working slowly
HELLO
By the fault you describe this sounds very much like a belt problem. Take the case off the deck and check the belt(s). Some decks can use more than one belt and you need to look at their condition.
Are they too slack around pulleys maybe? Belts don't last forever and I'm not too sure of the age of your deck. But personally, I would change them all.
Make sure the tape path is clean as well, clean heads, pinch roller and capstan.
Dec 14, 2009 | Audio Players & Recorders
I need replacement drive belts for an Onkyo
i bought some today from **** smith electronic store , i paid $7.97 for a pack of ten assorted sizes
May 18, 2009 | Audio Players & Recorders
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Mar 19, 2009 | Onkyo TA-RW244 Single Cassette Deck
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
Tape deck won't play.
Sounds like the belt that drives the capstan is too slack or decomposed, The capstan(s) which are connected to a geared flywheel, also drives the transport mechanism. There can also be tarnish on the sensor leaf switches, preventing contact. You might try to repair it yourself but, it is not an easy or simple job
Apr 23, 2008 | Onkyo TA RW544 Single Dual Cassette Deck
181 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
