Dvd burning when trying to burn, dvd, they will do encoding, analysing, then get to burn to 2% then freezes computer. the dvd's i am trying to burn are off our personal JVC everio hard disk camcorder.
Unit asked for region patch rpc1 ?
Posted on Sep 22, 2008
DVD player freezes while playing dvd, but will work if I fast forward
You have a scratch or marks on the disk. Try taking the disk out and cleaning it then trying again.
Or if this is a self burned dvd, then it is also possible that the video was not encoded to the disk properly. If this is the case all you need to do is burn another disk at a slower write speed.
Mar 28, 2011 | Toshiba SD-3950 DVD Player
Dvd for acer notebook won`t burn
1. check ur dvd can burn dvd or just read dvd 2. your burning software my not compatible with yor optical drive
Apr 09, 2009 | Acer Aspire 5100 Notebook
Video stream is jumpy .Download and burn movies that freeze up
How much free hard drive space and memory is in the laptop? Are you running anything else while the burn occurs? Have you tried a slower burn speed? DVDs hold more than 4 gigs of data. In addition to burning the video to the disk, the files are being encoded. There is really no practical way to speed this up. Make sure youre not running any memory intensive programs during the burn. 256 megs of memory is feasible, 512 megs or more would be better. Hard drive space--you must have free space on your drive at least double the size of the files youre burning.
Feb 28, 2009 | Acer Aspire 6530-5143 Notebook PC
Home dvd player won't play a burned dvd
Not all burned DVDs are compatible with all home DVD players.
Some things to do to help compatibility:
1. Use only DVD+Rs.
2. Burn at a slower speed (4x or below).
3. Make sure the software you are using to burn the DVD creates a menu. Most DVD players won't be able to play a DVD unless there is a menu; usually you can tell the software to skip the menu if you want but it still must be encoded onto the DVD.
Thanks and please take a moment to rate this solution with a fixya rating. :c)
Jan 25, 2009 | Ahead Software Nero 6 Ultra Edition...
Burning a slideshow
Try not to do other things while burning process is going on.
Thank U
Dec 04, 2008 | Roxio Easy CD & DVD Burning
Mysterious "ring" on burned DVD causes playback to freeze.
Is the image preponderantly encoded in PAL? Majority PAL and some NTSC? Or fully NTSC? Used transcoding presets? Transcoded project before you built to DVD? Note: Always run "TEST" before burning (to save plastic trees)? Determined whether system or project is faulty? Tested the DVD drive? Tried burning using another application? Closed all background-running resource hogs and applications? Did the project size increase the capacity size of the disk? Used a lower write speed? Disabled startup items and services? DMA: enabled? Updated Windows? Media compatibility? System requirements attained? Updated your application? Solved the issue(s); then write it down and share it with others. Still having issues? Revert back to the computer's factory settings and rebuild, upgrade, or invest in a high-end system and buy the full version of Nero 9, with all the plug-in features....and so forth. If time is money, the latter solution is your best bet. If money is an issue, then it requires trench warfare - that is, much research, deductive reasoning and time investment to isolate your specific problem...start by analyzing your source, and then your target...cause/effect relationship...you'll conquer all problems, eventually...political machinations aside. Ye all be happy computing Chomskyites. Dr. Frank Kohnstein.
Oct 29, 2008 | JVC DRM10 DVD Recorder
DVD recording freezes up
Freezing like this is usually a sign of lack of memory.
Ensure all other programs are shut down.
Burn fewer files at a time
Aug 30, 2008 | Roxio Easy CD & DVD Burning
Burning avi files to dvd
try version 8 works alot better!
Feb 06, 2008 | Computers & Internet
Burning
YEAH YOUR ENCODING SOFTWARE
TRY NERO VISION EXPRESS
OR AVI TO DVD CONVERTER
OR IF ITS ALREADY IN DVD FORMAT
USE NERO BURNING ROM TO COPY IT
Dec 12, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
'Strobing' on finished DVD
Amy, We would need a few more details about your video in question. Origional movie filetype, method of encoding, software used to burn, capture card used to create file etc. I do know for sure that making an ISO instead of a burning the folders or video files as a data/video DVD really doesn't do anything to help you with this problem. Also are you burning a traditional DVD or like many new players will play divx, xvideo, and windows media files. All of which could be burnt to a CD or DVD, and I have seen many files act similar to what your describing. Basically try to encode the video with another program and check to make sure you are using the appropriate frames per second. Here's a link to a free encoder that really works great for me. http://flaskmpeg.sourceforge.net/ O yea if you are trying to copy a vhs to dvd or a dvd without ripping the dvd you will get uneven audio, and video problems its called MACROVISION. good luck, Hack
Jul 11, 2007 | Ulead DVD Workshop 2 for PC
Computers & Internet Logo
David Payne
David Payne
