Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
DOESN'T PICK UP THE DIRT - Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
  • greenknight7 Feb 10, 2009
    Windtunnel Cyclonic Bagless Upright Vacuum
    does not pick up dirt and the brush roller does not spin correctly even though the belts have been changed.
  • 97 Answers
Try changing the belt and washing the filter. check for clogs and if you belts have been on there for more than 6 months then i would change it. hope this helps
Posted on Aug 02, 2009
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Doesn't pick up
This could be a few reasons. Check and make sure your bag is not full of dirt, a full bag will make your vacuum's suction worse. Next check for clogs of dirt and debris. Check the nozzle and brushroll too. If you find no clogs and the brushroll and belt look good, it may be your vacuum fan is damaged and needs to be replaced.
Genuine Oreck Mataxalloy Fan Impeller R0008
GoodVac.com
800-775-6586
May 09, 2012 | Oreck XL21 Bagged Upright Vacuum
Vacuum doesn't pick-up dirt
It's probably not picking up because the belt is worn and stretched. With a new belt it will pick up a lot better. Here is the belts you need:
Dirt Devil FeatherLite Belt
Apr 07, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum cleaner does not pick up dirt
check belt.if making a loud noise then you might want to check the impeller
Oct 16, 2009 | Vacuums
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Dirt devil vaccum #088915 won't pick up.
well the first thing i would look for is if the brushes turn turn it over bump the on off switch if it turns the belt is fine but u might have a clog in the bottom if that the case have to pull cover from thhe bottom take the belt and roller brush off and look up insde where the junk sucks up use a wire hanger if u need and after that clean out where the dirt goes in bag or canister........hope this helps
Dec 16, 2008 | Vacuums
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
181 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
