Question about Sony FD Trinitron WEGA KV-34XBR800 34" TV
Color Problem For some reason, my green and red colors haven't been working correctly. I've tried messing with the colors, hues, etc., but nothing seems to help. Is it possible to go back to the factory setting? Thanks.
  • 505 Answers
Ok try turning the tv of for (1)Hour by the power point and back on After and Hour Is UP. that way it will reset picture -
Make sure you un plugged it by the power point for the full 1hr
also make sure there is no speakers or anything magnetic within 90cm's of the tv this can also cause
the picture to have strange colors in the screen - if that happens simple Repeat the above
Posted on Sep 22, 2008
    Problem Solver:
  • 7 Answers
Im having the same proplem with a tube set.If it is projection,you may have to replace your convergance chips if it is a tube I my self Am waiting for,I hope it has a degousing program.
  • Jethroe Sep 22, 2008
    They should have a dionoistic code to get in on this set,I,am going to find a serivce guide some wher on the internet for my older 27 inch and hope they are in ther ,I would suggest going on the sony site and ask the same ?,if i find that there is a reset code on sony tube models I,ll give ya a heads up.
  • Jethroe Sep 23, 2008
    I removed the back of my set and found 2 adjustments that appear to be attached to some thick wires that rapp around in fugure 8s on the back of the tube.They may change the feild of the the screen this may get your colorsto re-line them selves or adjust the vertical and horzintal field ,Unfortunitly a pieace of the circuit board around my audio out jacks broke off .When you look at the back they have arrows pointing at every screw that has to be removed so you don'nt heard your circuit board remove ALLscrews with the arrows,then remove all the screws around the outside of the rear shell.Try to pull down the back at the top to the hinges at the bottom if you have any thing hanging up ,go back and make sur ALL the screws are off.the adjusstments are 2 plastic clinder knobs on the center right can adjust theses with the tube on ,they should have had theses
    come out the back ,put then you wouldn.t have somone like me break a small pieace of the board off
    ,missing the smallist screw. Ynplug set sit it on a flat bench where you can get to the adjustmens and able to see the screen at the same time.Plug it back in and turn 1 knob at a time until you get the disired degouse and H/V stretch ,i cant until I re soulder the audio out jacks back on and several other connections I broke by not seeing thte smallist screw. I bought it for 20 bucks ,but still one screw kept me from having a 720i t/v with a **** load of extras.Those wires I mention appears to be ATTACHED.TO A COIL THAT SEEMS WOULD SOLVE YOUR CONVERGANCE/DEGOUSING PROBLEM.with a hundred turns of a screw driver.
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Sony Wega model kv-32fs120. Color is all reds and blues, no greens or yellows. We have tried adjusting the hue as per the owner's manual and also the re-set but nothing changes.
The color of the television are compose of three color RED,GREEN and BLUE.So the lost color is the green.The problem is in the color section of the CRT board in the chroma section and in the CRT socket board.Maybe theres a loose connection in the PCB like the cathode output transistor.
Sep 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We have a JVC LT-32JM30 and recently for no reason at all, the picture color has messed up, we have tried resetting and adjusting the tinit, etc but nothing works. Everything is a varying shade of green or...
an internal degaussing coil circuit is already installed in the unit to neutralized color pattern...a loose solder connection may have caused this because as it operates temperature increases between the thermistor..
Jul 15, 2011 | JVC AV-27530 27" TV
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
There is too much green color, i tried hue - contrase - lite etc. but the color is still green
how do i get the red and green hue back on my olevia 227-s11 tv my screen is blue and brown
Dec 09, 2009 | Syntax OLEVIA LT20HV 20 in. LCD Television
Our Sony Grand Wega suddenly has a green-yellow tint.
Oct 06, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
The color on my mitsubishi model # vs-5041 is faded and foggy.
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
Hope this helps :)
Sep 16, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
I am on MS paint and i want a copper color. What are the codes for getting that copper color? example Hue: Red: Sat: Green: Lum: Blue:
Check out this setting for Copper color in Paint :
Hue: 27 Sat: 127 Lum: 124
Let me know if this fullfil your requirement. Otherwise you can edit the color yourself by clicing on Colors Menu --> Edit Colors --> Define Customs Color --> Then move the cursor to select the Color.
You can add this color in the Color Pallete to get in work. Let me know if you face difficulty, I will assist you further .
Vote if you get the exact solution for which you are looking for.
Thanks Scott
Dec 07, 2008 | Microsoft Computers & Internet
Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
117 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
