Question about KitchenAid KFP670 Ultra Power Food Processor
The plastic ? bowl of the processor is stuck
Thanks in advance for helping w/ this. The clear bowl piece of the food processor is stuck, the handle to the right of center. Seriously stuck. It looks like there is a spring mechanism in the handle that holds it in place.. but haven't been able to figure that out.
Jonischp\o
  • 1 more comment
  • Anonymous Dec 01, 2008
    I can put the bowl on but when I try to put the lid on it will not go on it is like the spring and the base do not connect.
  • panichols975 Feb 03, 2009
    I can't get the bowl off, or even move it to engage... What to do?
  • Mikey Rophone Apr 19, 2009
    i can't get the top off or move any part of the whole appliance. ugh. (i actually have the 650 but i assume it's the same as the 670)
    Sergeant:
  • 150 Answers
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
Posted on Sep 22, 2008
I removed the handle to clean under it and the parts came out and I cannot figure out how to put it back together.
I haven't seen any Kitchen Aid processors where the handle part of the bowl is dismantlable. I think you will find it is broken and you are up for a new bowl. The cover is normally glued on with no intention that it was ever going to be taken apart.
Sep 03, 2015 | KitchenAid KFP0711 KFP0711OB 7-Cup Food...
Tip
The Cuisinart 7 cup food processor will not start?
Check out this options Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the Food processor. If the motor doesn't spin, it needs repair. If there is spinning:Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work. This will help. good luck.
on Mar 08, 2010 | Food Processors
Pin dislodged in handle
KitchenAid Food Processor Parts
find your processor here and find parts
ereplacementparts has all kinds of parts available!!!
Apr 04, 2015 | KitchenAid 12-Cup Food Processor Chef&39;s...
Hamilton Beach food processor, model 70450, cracked bowl
You have a couple of choices here. The quickest and cheapest is to go to the hardware store, or a home depot and get a tube of one minute clear epoxy. This adhesive will repair the crack and since it is clear it will barely show. Plus it will dry in just one minute.
That said, yhou could also go to hamiltonbeach.com and get a new part.
Jul 11, 2009 | Hamilton Beach 70450 Food Processor
Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Jun 28, 2009 | KitchenAid KFP750 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
Instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
-Tha Mp3 Doctor
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart DLC-5 Food Processor
I have a kitchenaid kfpw760 food processor. I assembled it as per manual then added ingredients to work bowl, but...my ingredients are below the blade in the bowl and the blade doesn't contact the...
The work bowl lid has a feed tube on it, and the unit should have also come with a "feed tube pusher," a plastic piece to help depress food through the feed tube itself.
With a food processor, you will want to assemble the unit first, engage, and then add ingredients. This will ensure the ingredients fall through the blade and/or disc to be processed thoroughly.
May 11, 2008 | KitchenAid Professional KFP770 Food...
KitchenAid KFP670 Ultra Power Food Processor Logo
1,345 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Ross Keen
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
