Question about Vacuums
Kirby g 5 head bounces when vacuuming and tech drive is engaged, does not do this everytime
  • 120 Answers
First change the belt, even if it is not broken. also make sure that the height adjustment is raised up high enough, the higher the better ( when adjusting a vacuum you want the tips of the brush roller touching the tips of the carpet fibers ) also the same problem could occur on an area rug or any place the carpet is not securely held down ( the carpet can lift up and get sucked up into the vacuum )
Posted on Sep 22, 2008
Kirby Sentria 2 burning smell (not belt)
Actually it can. If the machine has a defect but the good news is that is has a 3 year warranty. Take it to a Kirby authorized repair shop not a vac and sew and they will fix it right up....I am a factory authorized service tech for the Kirby co.
Dec 16, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby g3 tech drive
so when u pull it back it's like it's not engaged at all? then it maybe the reverse is out....with the fwd soon to follow. remember the vac is 20yrs old; & working that long? it definately served it's purpose.
depending how much money you wanna spend on it buying a new or used trans. plus labor...or just an ebay used unit.
Mar 31, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Transmission not engaging
In Kirby vacuums with tech drive there is a part called Bracket cam (see it here) that is designed to disengage wheels from transmission. When it starts wearing out Kirby would make crackling noise when on neutral and eventually may not disengage at all. If there was no stage where it was noisy on neutral it may be something else - most likely the pedal assembly broken (see it here). It is not very hard to replace it.
Oct 26, 2008 | Kirby G4 Bagged Upright Vacuum
G5 Kirby drive problem
You need to adjust your transmission. Here's a link that may help...
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Re-connecting Vacuum Head
on the kirby head is a square knob with the kirby name on it. use your finger and pull out the belt and rotate the knob until the metal pawl engages the belt. keep turning until it stops. the belt should be in the correct position to install the head. place the whole head onto the lower two tangs and lift up. now rotate the wedge clamp until it stops. then rotate the belt lifter till the knob is straight.
Aug 28, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
159 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
