Question about Olympus Cameras
I need to reset my olympus e-520 to its default settings and i don't know how.
  • 43 Answers
Dear airwin433,
to reset your caamera to default setting follows the steps.
1. press menubutton(which is the second button from down in left side of your camera )
2. screenpops up in view fiender.
3. select the custom reset option.
4. there select th reset option ond press ok button.
and now your camera is resetted to default settings.
Posted on Sep 22, 2008
Hard reset Olympus E-520
1. Select P on the mode dial.
2. Open the card door and turn on the camera.
3. Hold down the Menu and the OK buttons at the same time for 5 seconds.
4. Olympus E-520 is displayed.
5. Release and again hold down the Menu and the OK buttons at the same time for another 5 seconds.
6. Reset has been done is displayed
7. Press the OK button.
8. Shut the camera off
Nov 22, 2013 | Olympus E-520 Digital Camera
The camera only takes black/blank pictures. I have no LCD screen. I am a novice, and this is my first SLR camera. I purchased it used off of Ebay, the previous owner swears that it worked when he sent...
Turn your camera off, remove your batteries for about 30 seconds and let it reset to default. Then try inserting the batteries and see if this helps. a link to go to is: www.olympus.com, then select americas, then select support, then select your camera, then download your manual in PDF format.
there is firmware built-in software which the camera uses to work properly. As a software, you can update it by connecting the camera to a PC and running the Olympus Master software that should have been included with the camera.
Then Set (PC MODE) in the E-300's (Set up Menu) to (Storage). If the operating system is Windows XP, remove the memory card before connecting the E-300 to the PC.
In the Olympus Master software Help Menu, you can look for "update firmware" to follow the instructions. Good luck
But be forewarned that it will only work if you have the newest Olympus Master Software Update, Olympus Master 2. Olympus Master 1.1 will not be able to connect with the online server. Luckily, Olympus Master 2 is a quick and free download from the Olympus site.
Otherwise this could be an intermittent shutter problem or speed setting going astray?
Look like it may be a trip to the Olympus Repair shop
Try to set all menu items to default as much as you can. Some cameras have a reset to default setting or a button to reset to default.
After setting to default, try the camera again.
If all fails, this camera will need repairs.
If it is too old, and not worth it, it may be the best to sell for parts on a site such as Ebay.
  • Dec 25, 2010 | Olympus EVOLT E-300 (Double Lens Kit)...
    Problem for Olympus FE-4000 Digital Camer: My camera lens was not moving in, what shall i do.
    http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?fl=&id=1354
    The above is for the fe-340.
    http://www.olympusamerica.com/cpg_section/product.asp?product=1466
    The above is for the fe-4000.
    I don't know which one you have.
    How do I change the shooting functions back to default settings?
    You can reset the current settings to the camera's default settings by using the RESET function. RESET is available from the camera menu when the shooting mode is set to iAUTO, P, SCN (Scene), Digital Image Stabilization or Movie. Simply press the [MENU] button, press the Left Arrow to select the reset icon (a green arrow bent backward on itself), and then press the [OK] button.
    The following table shows the functions that can be reset as well as their default values.
    FUNCTION DEFAULT Flash AUTO Exposure Compensation 0.0 Macro OFF Self-timer OFF Image Size (Still images) / Compression 12 M / Normal Image Size (Movies) / Frame Rate QVGA / 15 fps SCN Portrait WB (White Balance) AUTO ISO AUTO _soundrec.bmp (Still picture REC) OFF _soundrec.bmp (Movie REC) ON AF Mode SPOT
    but_up.gif What type of memory cards does this model support?
    Olympus recommends Olympus-branded xD-Picture Card media for use with this model. In addition, certain microSD and microSDHC cards may be used when inserted into the MASD-1 memory card adapter bundled with this camera.
    For detailed information about the proper use of the MASD-1, please review the MASD-1 FAQ. For information on caveats and restrictions to the use of microSD and microSD media with this camera, please review this file.
    Aug 03, 2010 | Olympus FE-340 Digital Camera
    My Olympus E-520 says that the card is full but there are no pictures on it. What could be the problem?
    Go into the camera menu and find "reset"...follow the on-screen instructions. Then, format the card in the camera.
    Dec 22, 2009 | Olympus E-520 Digital Camera
    Olympus E-520 DSLR user's manual in .pdf format
    You can download your manual here:
    http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1386
    Dec 02, 2009 | Olympus E-520 Digital Camera
    Master Reset Olympus x840
    To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight yes and press ok. This will set the camera back to factory default settings. Hopefully this should solve the issue.
    Apr 13, 2009 | Olympus FE-210 Digital Camera
    Battery cover for Olympus D-520 Zoom camera
    https://emporium.olympus.com/innards/emp.asp?counter=&p=16&getparts=yes&productParts=857&submit1=Go
    Here is the link to the Olympus parts website where you are able to find the replacement part you are looking for
    Feb 23, 2009 | Olympus Camedia D-520 Zoom Digital Camera
    Need to factory reset E-Volt 500 Digital Olympus Camera
    Put camera dial on P - go to Menu - camera 1 tab is highlighted - right arrow over to card setup - down arrow to custom reset setting - right arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera should now be in factory default settings
    Dec 24, 2008 | Olympus EVOLT E-500 Digital Camera
    Cameras Logo
    775 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
