Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
Not show a drive - Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
Click start Go to my computer go to hard drive right click go to propeties click hardware click properties click driver go down to uninstall pc will restart then pc will find new hardware then restart one more time ( FIXED ) (- .'
Posted on Nov 14, 2008
Toshiba 500gb portable drive only shows 230gb after imaging my c drive
Sounds like you cloned the drive. Yes? Plug the external drive in, go to
Windows Button > Right click Computer > Manage > Disk Management.
Select the external drive and right click and select extend volume.
Feb 02, 2013 | Computers & Internet
I can't get the drive to show up on my computer anymore, it was my F drive, simpletech model 96300-400001-001 what can I do I need my important info
Sadly external drives do fail . possibly a computer repair shop can access it and get your information back , but it is costly
Aug 21, 2017 | SimpleTech Computers & Internet
My computer will not pick up my drive when i put it in
The windows disk management utility will help solve this issue most of the time. Use the directions below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 20, 2011 | Computers & Internet
My sea gate external hard drive can not open and my computer can not read it
Using the windows disk management utility. This will tell you if the hard drive is connecting to the computer or if it is a hardware problem. Sometimes, power cycling the external and restarting the computer will help. Below are the directions for using this utility:
A menu will open
Chose "Manage"
Please remember to post positive feedback if this solution was helpful. If not, please let me know and I will assist your further.
Thank You,
Brian
Jan 25, 2011 | Seagate FreeAgent Go 500 GB USB Hard Drive
New 1TB My Book Essentials ext drive not recognized by laptop
There are times when external drives need to be inialized and formatted before they can be recognized by a computer. There are other times when the drive letter that the external is looking for is already being used and it does not show up.
You can use the disk management utility to initialize, format or change drive letters around. You do not want to change your C drive, also usually called drive 0. Below are directions for accessing and utilizing this tool:
A menu will open
Chose "Manage"
This should get you to see your external. If you don
Jan 16, 2011 | Western Digital My Book Essential 1TB...
How do I access what is on the passport? It does not show up when I click C:
As long as it is plugged in it will show in windows explore. Click on "my computer" or Start,computer. In the window it should show up as drive "D" if you have no recovery partition or drive "E", etc... it won't show under the "C" drive as it isn't part of it.
Jan 01, 2011 | Western Digital WD Passport 250GB Portable...
My san disk 2gb pen is canot open but light is blinking &showing remuvabal disk on my computer
USB Pen or stick drives usually use the letters "F" or "G" drives on your computer. If these drive letters are being used, the USB drive will not be available. Also, if this is the first time you are using the USB drive, it is possible the drive is not formatted. Although this is unlikely.
I will outline instructions below to use the Disk Management tool in windows to see if the drive shows all the drives connected to your computer. If your computer is recognizing the drive as you describe. I am confident USB Pen drive will show up in disk management. You may be able to assign a drive letter and make the drive visible in you my computer window.
The directions for using disk management are listed below. A note of caution, do not make any changes on you Disk 0. or "C" drive, as this is you main hard drive that starts your computer.
Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu. The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have no disk will not show as active drives on the top section, but can be seen in the lower section.
The lower shows each drive, their drive letter and status. The left section will have small boxes showing drive numbers. Drive 0 is usually your main hard drive. To the right of the smaller section is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”) This is the area you can right click and get a menu that will allow you to: open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition.
In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows. A drive this is having a problem may show that it needs to be formatted. This can be done from this window as described above.
Please follow these directions and see if you can make your drive visible. If you have any questions about the instructions or need further assistance, feel free to reply to this message and I will assist you further.
Brian
Jan 29, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
C drive showing 0bytes and won't format but D drive shows 33GBs??
No. As each drive is on it's own "circuit" then they each show as good or bad. Try taking the drive out and making sure that it is fully in and retrying as sometimes a loose connection will cause a lost drive.
May 17, 2009 | Acer Computers & Internet
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
37 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
