Question about Zenith C27A24T 27" TV
Zenith 27"h2521y3 How do I get my tv out of channel lock?
  • matthew91 May 05, 2009
    the tv channel wont change unless the auto program recognizes the channel....how do i freely change trough al the channels
  • 790 Answers
Hi
What do you mean?
thanks!
Posted on Sep 22, 2008
Does the Zenith A27B33W need a digital converter to get broadcast television? (not cable TV)
Turn on your Zenith TV and try selecting channels. If you see channels such as 10.1, 52.2, etc. displayed, they are digital. If you do not see digital channels displayed, you will need to purchase and install an A/D converter (set top box).
Feb 23, 2015 | Zenith A27B33W 27" TV
Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
Mikeywaf
May 22, 2011 | Zenith C27A24T 27" TV
How do you open the menu to do an auto channel scan on a zenith H2521Y3 without a master remote. It is an old ''hotel tv'' that I ''thought'' I got a good deal on.
These hotel t.v use a particular remote so that customers can`t fool around with the setup,You may be able to get an eeprom i.c for a similar chassis from a local repair shop, but then your set may need some adjustment through the service menu i.e vertical and horizontal size, a local tv repairman may be able to help you there. good luck
Nov 12, 2009 | Zenith C27A24T 27" TV
Change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Dec 19, 2008 | Zenith C27A24T 27" TV
My tv wont let me auto program the channels
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
Dec 13, 2008 | Zenith C27A24T 27" TV
My tv is locked
They have an internal battery for transport between rooms so as not to lose any pre-programed channels or info while unplugged. So to beat this you will have to unplug it for a few days and let it clear its memory. Mine needed almost a week but when its turned on after the right amount of time it will ask to do a channel search. So make sure you have it hooked up to cable before running that search or you will have to repeat the previous steps. Hope this helps.
Zenith h25w35dt
You need to go into the service menu and turn the ac power setting to off and read to see if you can get the channel to scan To enter service menu: hold down menu on remote until menu disapperar then type in 9-8-7-6 then enter. Continue as described
Jan 02, 2008 | Zenith Z27A11G 27" TV
Zenith SR3238RK
You have to access to the service mode , press at the same time channel up & down and the adjust button up , you will see a menu, find with the remote the funtion channel lock the values are 0 or 1 select 0, now Should be in 1 and that`s because you can not change channels , good luck , please dò not change any other value or better, writte down all the values before you change any.
Dec 29, 2007 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
104 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
