Kodak EasyShare C643 Digital Camera Logo
Anonymous Posted on Oct 12, 2011
How to fix cloudy lcd screen - Kodak EasyShare C643 Digital Camera
1helpful
My lenovo t61 screen is cloudy white
definitely hardware sounds like yo have a disconnected LCD cable or most likely its a bad lcd screen
1helpful
Screen has gone cloudy?
Kevin, Kevin, Kevin,.....you should have posted your problem here first.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
In regards to the Acer Aspire 7720 series of Notebook PC's, the Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Approximately 2mm Wide, by close to the height of the LCD screen, Tall )
A screen Inverter is used to convert the power (Electricity) of the laptop, for the Backlight, and LCD screen.
http://www.cdsparts.com/p-97-new-acer-aspire-7720-7720g-7720z-7720zg-series-lcd-inverter.aspx
90 PERCENT OF THE TIME THE FAULT IS THE INVERTER.
The thin plastic frame in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is mounted towards the bottom of the LCD screen, and behind the Display Bezel.
This you already know. Posting for those who read this solution in the future.
Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
For additional questions please post in a Comment.
Regards,
joecoolvette
I have a very small cloudy type smear on my Olympus epl2 lcd screen. It's not a scratch because the surface is very smooth. What caused this and how can it be corrected? Cheers, Jim
I don't have an E-PL2 to look at, but it looks like there is a protective window over the LCD screen on the back of the camera, that is why it is smooth.
If the "cloudy smear" is see-through-cloudy, then it's either a water spot under the glass or dust.
If you can't see anything on the LCD in that spot but big splotch, then the LCD is cracked and needs to be replaced.
Without being able to see it, I can't say 100% sorry.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 • Cameras
1helpful
Hitachi 50v500 reddish cloudy swirl sweeps across
motherboard has gone out cost is about $700 including labor i just was quoted that price mine is doing the same
Tatung plasma has cloudy screen. In and out seems to depend on backround color if picture is bad or not
That was the first generation, I would invest in another set considering the age and parts availability.
2answers
Cloudy LCD
I think camera screen (LCD) is broken thats why you getting image as cloudy.
1helpful
Cloudy patches from backlight leakage in LCD TV
You have to send it back to company to fix this problem>
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
2answers
Cloudy TV Screen
If you can remove the front screen, look down into each CRT tube lens, blue, green & red see which ones are cloudy. The cloudy ones need the fluid changed which is a coolant. Shops charge between $75 to $150 a tube to change.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
