Color on corners of tv on the left side dont match up some of it is red some blue
    Sergeant:
  • 152 Answers
You need to adjust your the color convergence to align the colors most projection tv have this setting.If the tv was bumped real hard it may have to be adjusted by a professional.
Posted on Sep 22, 2008
18c808 aa subwoofer with amp from Focus. How do I install it?
ask here
http://www.f150forum.com/f75/how-fix-your-subwoofer-amplifier-7l2t-18c808-aa-227544/
or
Diagram 7l2t 18c808 aa - Dual Ford Mustang Convertible 94-12 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
Oct 23, 2015 | Ford Cars & Trucks
I bought a powabyke on ebay and when it arrived I noticed that there was wires unattached beside handlebars where throttle cable joins throttle but the colours don't match the cable coming upwards has...
if its for the key area try red red ,black black, yellow orange, white grey, blue,green , kinda the same on some tailer hookups.
the other colored wires that dont match as well are distributed to the turn signals. if they work as they should after the above mentioned hookup great!.
If not just try switching the orange and blue wires again because one is left one is right side.all the power and grounds are the same,good luck, Gary
Oct 25, 2013 | Cars & Trucks
I HAVE A PT-65WX50B PANASONIC BUT THE SCREEN I SEE THE 3 COLORS RED BLUE GREEN -THE MENUE DONT LET ME GO TO THE OPTION TO SET THE COVERANCE HOW OR WHAT I NEED TO CHANGE ,THANK YOU
more than likely the red and blue component cables are crossed at the cable box or TV double check make sure the colors match on both the cable box and TV set
That should fix it up nice
Dec 03, 2010 | Televison & Video
Trying to wire new stereo for my 98 taurus, but wire colors dont match up! where can i find factory stereo wiring schematics
Hello I have included a wire color code for you installation. Hope this helps you out. Please rate and good luck. Israel
Constant12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination light blue/red
Left Front + Orange/light green
Left fRont - light blue/white
Right Front + white/light green
Right Front - dark green/orange
Left Rear + gray/light blue
Left Rear - Tan/Yellow
Right Rear+ Orange/red
Right Rear - Brown/Pink
Apr 13, 2010 | Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Locked tv
What is the make and model number of your flat screen tv.
Mar 11, 2008 | Televison & Video
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
