Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dc07 problem I have a dc07 cyclonic vaccum and like this model,however, for some reason,it has been very dificult to push and pull for the past month or so. i have completely cleaned the brush assembly,cleared any obstructions in the hoses,and, cleaned the filter.I also checked the belt tension,wich i thought was fine but to no avail.Be advised that the brush assembly is spinning and suction is excellent. It just feels like the brush drags along the carpeting. this is a great vacuum cleaner and i refuse to give up on it,so if you can think of any else i can do to improve it"s performance,it would be greatly appreciated. Sincerely yours, JESMAN72
  • 120 Answers
The dyson uses two belts, one from the motor to a clutch and then from the clutch to the brush roller, the belts that they use are not much better then any other belt ( those you should change yearly ) but you cant just change the belts you have to change the entire clutch assembly itself ( you can get it at sears ) but it is not an easy job you might want to take it to a repair center.
Posted on Sep 22, 2008
The dust collecter is stuck and won't release from the vaccum. how do i release it to empty.
Make sure you switch off the vacuum cleaner.
Here is the instruction to remove the bin
Press the cyclone release catch with your thumb to remove the
clear binTM assembly from the machine.
• When removing bin, do not pull up on carry handle while pressing cyclone release catch
• When replacing the bin, ensure it clicks back into place.
Dec 31, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can anybody recommend a reasonably priced vacuum cleaner that works well and either has bags or is easy to empty?
We use both a Eureka Multi-cyclone and Dyson DC07. They are both easy to use and empty and do a good job. The Eureka was several hundred dollars cheaper.
Nov 09, 2014 | Vacuums
There is no suction on my vaccum, hoses appear not to be blocked
have you checked your permanent filter. is that plugged? Have you taken the small solid plastic passage off the side of the machine and checked for a plug there?
Did you by chance rinse your cyclone with water at some point? You can disassemble the cyclone and clean that. google has some videos on cleaning your cyclone. just google clean dc07 cyclone and you'll get several
Sep 21, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suctions except when using hose
There is probably a clog between where the hose and brush. If there are any removable flexible sections, pop them off and have a look. If you have access to an air compressor that is a very quick and easy way to blow the clog out in reverse flow path. If you do blow it out I recommend doing this outdoors as it makes a mess. If you do not have air then you need to find a ridgid flexible rod of some sort to push the clog or hook it and pull it out a little at a time.
Jul 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When I push in the power button to start my Dyson DC07 pink it will not stay on. Any reason for this?
Hi its Darran at Dyson.
It sounds as though the switch needs to be replaced. Please call our Helpline on 1866MYDYSON so that one of our advisors can assist you.
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I need more suction. The Head is too high on my carpet.
Hi.
A slitght adjustment can be made by either screwing on short transparant internal hose on top of floor head tighter or undoing it turn.
Do this on A table as you need to get down to be able to view sole pate movement
Each time you adjust hose stand vac up on the table & pull handle back as if cleaning carpet you must not push head of vac down on the table.
Now look at sole plate usually when they are wrong the sole plate bottom back end tilts up lifting brush from carpet.
Now tap front of head down if sole plate springs back up lifting brush up again adjust hose a bit more.
What you are trying to do is get sole plate as horizontal as you can.
If you really cant get it to pick up dirt any better try fitting new hose they are more sprigier from new,
http://dysonmanuals.llc.nu/
Jan 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Not sucking, floor
the filter can be located at the bottom of the vaccum where the motor is if you look on the right of the machine you should see a little yellow or silver catch if you push it back you should be able to pull out the large round disc looking object this is your filter housing once removed pull out the yellow casing which may be pretty tight underneath sits the filter after you wash the filter make sure its completly dry before you replace it
Oct 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Washable filter clogging
They have bad seals that allow to much dirt to get through, order new cyclone assy $80.00 it will be fixed on model dc17 very big problem
Oct 12, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson vaccume cleaner
Remove sole plate by turning 3 plastic screws to unlock then pull plate off.
Check belt has not snapped.
If your machine is all floors with clutch check that selector knob on front side of machine goes to (D) or drive when you pull the handle back.
Let me know how you get on.
http://dysonmanuals.inc.io/
Chris.
Dec 09, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
554 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Dyson Solutions...
Dyson Solutions...
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
