Washer has stopped after the wash program and before it drains leaving the tub full of wet washing. Have tried different cycles to make it empty, to no avail. would it be better to buy a new washer? I've had it for eleven years and this is the first time it has broken down.I really love it and every other washer comes second best.Icant find arepair man in my state,do you know of anyone?
  • pamandjimmy Sep 22, 2008
    Sorry forgot to mention its a Hitachi Top Loader,Model no SF-60PX
    Genius:
  • 1,028 Answers
Without brand or model would be tough to say but suspect lid switch first
Posted on Sep 22, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
The water will not drain. The tub starts
The pump is clogged. The only way to fix this is to clamp off the hose to the tub and remove the hose from the pump and remove what ever clogged the pump. Expect to get a little wet.
Mar 04, 2010 | GE WBSR3140DW Top Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Drain and spin cycle
Okay...the problem may be that you have something caught in the drain pump preventing the impeller from turning. Or, the pump itself may have stopped working. If you experience a problem where the washer does not drain or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Please read ALL instruction before attempting.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the screws at the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located under the wash tub (it is the only pump this washer has).
4. The pump can be removed and the housing taken apart to clean out the impeller trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and place them under the pump. Remove one of the drain lines and allow water to drain. If the tub is still standing in water (as you stated) bail as much from the tub before removing the drain lines from the pump (if you are using the towel method for collecting water).
6. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the housing cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select a wash cycle. Allow the tub to begin filling and check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping.
10. If there are no leaks, you can stop the wash cycle at any time and select a drain cycle. If the drain pump works normal, reinstall panel and tighten screws.
11. If your pump still does not run, more than likely, the impeller motor is damaged and the entire pump must be replaced. The motors typically are the part that fails on this pump. Follow the previously mentioned procedures for removing water from the wash tub.
NOTES:
a. Your pump is item #916709 at repairclinic.com. Or part number 134051100 at searspartsdirect.com. Just type in your model number in the search menu and a parts index with pricing is made available to you. the pump is listed as an "askoll pump" under the "Tub" header at the Sears website. HINT: Sears has it a little bit cheaper.
b. It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
I hope this information is helpful. If you have any questions/concerns, please post back with your comments. Good Luck.
Feb 27, 2008 | Washing Machines
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
