Question about Hitachi 43UWX10B 43" Rear Projection Television
Have a hitachi tv model number 43uwx10b seial number v1k034070 picture is fuzzy
SOURCE:
SOURCE: 43 inch Hitachi UltraVision model # 43UWX10B
hitachi 43uwx10b will not turn on. red power light just flashes
Posted on Apr 06, 2008
  • 927 Answers
SOURCE: Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Posted on Sep 06, 2008
doin12volt
  • 233 Answers
SOURCE: Blue and yellow shadows on my Hitachi rear projection TV
The color has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps!
Posted on Dec 21, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Hitachi TV, has red ghost lines outlining image on screen! Help!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 24, 2009
SOURCE: Manual Convergence adjustment on Hitachi 43UWX10B
I'm not sure if this is the fix yet but took out convergsnce board and found one of the resistors to be burnt will replsce tomorrow and repost if good news
Posted on Nov 04, 2009
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Hitachi 43UWX10B - LED Light on constantly on will not go off
Power relay is defective. All contacts are not opening when power is removed. Located on small power supply board, upper rt side.
s 901 part# FJ00142 should be under $10, do a google search with part number and 50 sources will appear.
easyab
s901, FJ00142
Jul 14, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I would guess you missed a open resistor--there are only about 12 of them--how did you check them?
This set (43uwx10b) has a tiny blue micro switch on the front of the chassis---if you engage it from the front the set will go into the DECAM or convergence mode--let me know the CLU number on your original remote and I will scan and paste instructions---98% of the time if the set is wacked out and will not adjust one of the resistors is gone---ONE OF THE CHIPS GETS THEM.
SD TECH
Oct 31, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi model 43uwx10b comes but no sound or
sounds like one of the transistors attached to a heat sink shorted out.
you will need to test each one with the tv unplugged.
set the digital meter on diode.
it`s not easy to explain the rest, sorry.
Sep 08, 2009 | Hitachi 43UWX10B 43" Rear Projection...
43UWX10B Hitachi rear projection HD ready TV
Replace Convergence ICs STKs will have Part # on them big black ics For parts 1-800-223-3205 www.electronix.com you have 2 of them replace Both!
Jan 03, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Good Day;
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Looking for convergence part number
yes they are the same Convergence ICs number STK392-110 you need to replace both ICs. You can get replacement ICs at the following link and they provide free instalation instructions with pics so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 12, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10b tv ceeps bepping or cherping
Research at www.HitachiServiceUSA.com....................T.
Nov 04, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Sep 30, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
