Need to replace ink cartridge on a MP160 printer
I lost my manual for the Canon Pixma MP150 how do I put the cartridges back in the slot?
Posted on Dec 30, 2008
Canon MP160 Printer "Ink Absorber is Full
Canon MP160 PIXMA shows ink cartridge full. How do I I just refilled with new cartridge, due to stating no ink. Please help..thank you.
Mar 12, 2013 | Canon PIXMA MP160 All-In-One InkJet...
I have been given a canon pixma MP160 with no ink cartridges. what sort do I look for in the store.?
This printer uses 2 ink cartridges.
  • Ink Cartridge Configuration 1 black cartridge, 1 color cartridge (cyan, magenta, yellow)
You need to purchase the cartridges that suit this model printer.
If the printer does not print properly then the printhead may be faulty and needs to be replaced, BUT these are expensive. It may be better to put your money towards a new and better printer as a new printer is not much more expensive than the cost of a new printhead.
Jun 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma mp160 cartridge slams to right side e5 error
you need to replace the cartridge,with a new one original canon,not refill
Mar 03, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
I installed a new black cartridge and now it is not printing. I need the installation guide for allignment
Please follow below instruction. Otherwise, visit this link. Link
We hope we have provided you a solution to your problem.
Thank you.
The Canon Pixma Mp160 is an all-in-one printer, scannermag-glass_10x10.gif and fax machine. Replacing the cartridge in the printer requires little effort. Make sure to use the correct replacement cartridges for your MP160; installing the wrong cartridge type could prevent your printer from working or cause it to fail. Use caution to prevent ink spilling or dripping on you.
Step 1 Identify the cartridge that requires replacement. Press the "Copy" button to display the ink level. "BLK" indicates your black ink cartridge; "COL" indicates your color cartridge. If the display is only one bar (or none), then the cartridge should be replaced.
Step 2 Open the top compartment (scan lid) on your Canon printer. Pull back the compartment support legs to hold it open.
Step 3 Put on gloves, and then push the cartridge down to unlock it. Pull it toward you to remove it from the printer.
Step 4 Remove the tape strip from the replacement ink cartridge. Insert the new ink cartridge (black on the left, color on the right) at an angle, with the gold circuit facing down and towards the front of the printer. Push the cartridge up to lock it in place.
Step 5 Repeat the process if you are replacing multiple cartridges. Close the scan lid when you are finished. If the "Low Ink" warning does not go away, then turn the printer off, wait a few minutes and turn it on again.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Getting ERROR 5 message in my Cannon MP160 MFD
When your printer ink cartridge is ink run out or not support then rise this fault code.So you need a new cartridge.Insert new cartridge then solve this error.
Apr 11, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How to fix problem E16 in my printer canon mp160
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
Sep 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E5 - The ink cartridges are not installed, or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
E28 - Ink cartridge temperature rise error.
Replace the cartridges.
Call to authorized service center.
Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to change ink jet cartridge canon 'pixma' printer mp160
Please go to this Canon link (click here) and enter the term "ink cartridge replacement" in the search window for a set of detailed instructions (with pictures) on how to replace your ink cartridges.
As you face the printer, with the scan cover open,in position to remove them, the black cartridge goes on your left and the color on the right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Change ink cartridges
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Oct 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
363 people viewed this question
