Toshiba 30HF85 30" TV Logo
Posted on Sep 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba TV Remote Control not working
My remote controls to my Toshiba TV stopped working yesterday. I have three different remotes to the TV, Once in a while I may get it to actually change the channel ,or turn the volume up or down. But it will only do it ramdomly and then it wont do it again. Ive reprogrammed my remotes, and changed the batteries in them, So I dont think thats the problem. Any Suggestions would be appreciated. Thank You. It is not with the remote, it is in the TV. I read on 1 forum that the eye can have a bad solder connection, but I haven't checked into it.
Anonymous
Level 3:
  • Master 790 Answers
  • Posted on Sep 22, 2008
Anonymous
Master
Level 3:
Answers
790
Questions
6
Helped
225264
Points
1965
Hi
can you give to me your exact problem?
Thanks!
1 Related Answer
David Landress
  • Posted on Dec 19, 2007
SOURCE: Toshiba TV Remote Control not working
I unplugged my wt-42315, counted to 60, plugged it back in, and voila, the TV responded to all my remote controls again.
Need codes for toshiba tv
Here are the codes for a Toshiba TV and DISH remote:
617,631, or 744AddressRemote to TV
  1. While at the device location (TV, etc), point the remote at the device. Press and hold the device button on the remote (TV, Aux, etc). - All four mode buttons should light up
  2. Enter the three-digit remote control code - The mode button (TV, Aux, etc.)you selected should light up
  3. Press the Pound (#) button - The mode button you are programming should flash three times
  4. Press the large, red POWER button - The device should turn off
I just bought a new remote and cannot find the user guide for the TV. Do you need to program the remote for it to work?
Hello
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
[4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
[5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
OK.
TOSHIBA SER0324 Remote Control. I just got a Toshiba TV with this remote and I am unsure how to set it up.
Hello
You can prgramme with
toshiba remote control with Toshiba TV, eventhough you haven't its manual or codes. Proceedings are :
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
No sound control: Toshiba T.V. set. ; Hand remote
Hi, Cheri Torres with DISH Network Customer Service. I came across your post and wanted to see if I could help. The information you provided leads me to believe that you will need to address your DISH Network remote to your Toshiba TV. There are a few different codes for each of our different models of remotes. I will list here for you the codes for our more popular models of remotes and also the instructions for addressing your remote to your TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me anytime at [email protected] and I will be happy to help!
Instructions for addressing the remote to the TV
  1. Turn the Television On
  2. Press and Hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button.
    Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
Remote control stopped working.
resolder the board on the remote as well as clean all the oil from the control pad
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
60helpful
12answers
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
