Question about Canon PIXMA MP600 all-In-One InkJet Printer
Need to locate the cartridge on the MP160 printer
I need to replace the ink cartridge on a MP160 printer. Need illustration.
    Scholar:
  • 116 Answers
You just have to keep the printer in the ON condition and lift the upper cover which also contains the scanner unit .do not just lift the scanner lift whole upper unit its like a flap it will be easily lifted.and after lifting the cartridges will move and come to the position and stop at the position at which you have to remove the cartridges from the printer.its very easy you just have to pull the cartridge towards your self do it slowly to understand the procedure.so you can do it normally next time.in the same way you can insert the cartridges.
Posted on Oct 05, 2008
I have been given a canon pixma MP160 with no ink cartridges. what sort do I look for in the store.?
This printer uses 2 ink cartridges.
  • Ink Cartridge Configuration 1 black cartridge, 1 color cartridge (cyan, magenta, yellow)
You need to purchase the cartridges that suit this model printer.
If the printer does not print properly then the printhead may be faulty and needs to be replaced, BUT these are expensive. It may be better to put your money towards a new and better printer as a new printer is not much more expensive than the cost of a new printhead.
Jun 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma mp160 cartridge slams to right side e5 error
you need to replace the cartridge,with a new one original canon,not refill
Mar 03, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
I installed a new black cartridge and now it is not printing. I need the installation guide for allignment
Please follow below instruction. Otherwise, visit this link. Link
We hope we have provided you a solution to your problem.
Thank you.
The Canon Pixma Mp160 is an all-in-one printer, scannermag-glass_10x10.gif and fax machine. Replacing the cartridge in the printer requires little effort. Make sure to use the correct replacement cartridges for your MP160; installing the wrong cartridge type could prevent your printer from working or cause it to fail. Use caution to prevent ink spilling or dripping on you.
Step 1 Identify the cartridge that requires replacement. Press the "Copy" button to display the ink level. "BLK" indicates your black ink cartridge; "COL" indicates your color cartridge. If the display is only one bar (or none), then the cartridge should be replaced.
Step 2 Open the top compartment (scan lid) on your Canon printer. Pull back the compartment support legs to hold it open.
Step 3 Put on gloves, and then push the cartridge down to unlock it. Pull it toward you to remove it from the printer.
Step 4 Remove the tape strip from the replacement ink cartridge. Insert the new ink cartridge (black on the left, color on the right) at an angle, with the gold circuit facing down and towards the front of the printer. Push the cartridge up to lock it in place.
Step 5 Repeat the process if you are replacing multiple cartridges. Close the scan lid when you are finished. If the "Low Ink" warning does not go away, then turn the printer off, wait a few minutes and turn it on again.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Getting ERROR 5 message in my Cannon MP160 MFD
When your printer ink cartridge is ink run out or not support then rise this fault code.So you need a new cartridge.Insert new cartridge then solve this error.
Apr 11, 2010 | Canon PIXMA MP160 All-In-One InkJet...
CANON MP160 PROBLOM E5
E5 - The ink cartridges are not installed, or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
E28 - Ink cartridge temperature rise error.
Replace the cartridges.
Call to authorized service center.
Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to take out cartridges and then replace
Go to this page. Type "replace ink" in the search screen in the center of the window and click on the Search button. Now click on the link for replacing the cartridges, and you will have an illustrated, step by step guide. Note that the unit must be powered on when doing this.
Mar 25, 2009 | Canon Office Equipment & Supplies
Replacing black cartridge in Canon MP180
Go here. In the search window in the center of the screen, type "cartridge" and click on the Search button. Now select "How do I replace the ink cartridge(s)" and you will see an illustrated, step by step guide. (Note that the printer must be powered on when doing this.)
Mar 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Where are the cartridges so I can replace them?
I suggest that you go to the Cannon site and look for the manual for your printer. It should provide all the information that you need to replace the ink cartridges.
Jan 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How do I install a new ink cartridge, and remove the old one?
Go to this link. In the search window in the center of the screen, type "replace ink" and click on the Search button. You will get a list of answers that show you step-by-step illustrations on how to replace the cartridges.
Aug 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
