Question about Video Game Consoles & Games
Psp is not reading disks. motor is not spinning.
    Problem Solver:
  • 23 Answers
Try get a refund from the store,or try sending it in to sony.If it has custom firmware,I'm not sure if it voids the warranty.If your warranty has long been pasted,i think you can send it in for repairs,but for a fee.It would be cheaper than buying a new PSP.
Posted on Sep 22, 2008
Evey time i but in a umd it comes on and then says disk can not be read
It could be many things is the can be a bad lazer, disc rotating motor is stuck, or bad motherboard in a worst case scenario. You can check if your lazer and your disc rotating motor is working if you open your umd slot with the psp on and with a small toothpick there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive If you press this down, you should see the disc motor spin and the laser light up red. If they are in working order then it could be something wrong with some of the other hardware in the psp itself. (Caution: Do not stare directly at lazer) If one of the motor (Lazer or Disk rotating motor) are twitching or trying to move there could be some dust in the gear preventing it from turning you can try getting a needle and try to move the gear manually. If this does not work your most likely going to need to send it in for repair. Hope this helps please rate thanks!
Feb 26, 2011 | Sony PlayStation Portable (PSP) Console
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
After this try and see if it is reading UMD again.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
PSP not reading UMD motor not spinning
This unfortunately is a fairly common problem with PSPs. I would recommend giving Sony a call, there's a good chance it's still under warranty. Their number is 1-800-345-SONY (7669)
Jul 08, 2009 | Video Game Consoles & Games
My son's psp will read some games but not all of them. What is wrong with it?
It could be that the outer casing is broken or the disk isn't spinning right inside the outer casing. I had this problem with a game my friend gave me. The case was broken so it didn't work. If the disk doesn't spin fast enough, it will cause a read error . I learned this also. I have seen replacement cases for psp games so you can always put the game in another case.
Jan 20, 2009 | Ubi Soft Asphalt: Urban GT 2 for PSP
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
PSP "DISK COLUD NOT BE READ"
when a psp is starting to read a disk, it takes up 333 mhz of processing power to to read it. thas why u dont see anything when u come from off or sleep into on w/ games inside of teh drive. its normal. all psp's do that. now ur laser is bad get another drive or use rubbing alcohol on a qtip and clean it,
plz rate thnx
Jul 13, 2008 | Sony PlayStation Portable (PSP) Console
Psp not reading umd discs
if the disks dont load then it is because your motor that spins the discs has worn out
Apr 26, 2008 | Video Game Consoles & Games
Sony psp
have you tried various disks? certan disks may either be scratched or dusty so you coul take a can of compressed air and ust out both some umd's and the umd tray of the psp. also, if you're usuing a custom firmware, you may find it will work once you revert to an official firmware
Jan 19, 2008 | Sony PlayStation Portable (PSP) Console
Psp
Hi Jleew,
You should check to see if another UMD will work first.  Also try them in another PSP.  If your sure your PSP is not reading Discs, then and only then, Clean the Laser lens carefully.  Using a strong flashlight and magnifying glass, look into the UMD drive with the UMD door open and look for debris like hair or lint, and also dirt and dust.  A black switch pokes up on the left inside the UMD drive.  Its a little black stick.  When you press down on this Black stick, your UMD disc motor should spin for  second or two.  The UMD laser lens should light up when your press this switch.  If any of this does not happen, you need to replace the UMD drive. If you need someone to do this which if you have never done it, you need some knowledge big time.
I can do this for you if you're in the USA for $55 including a New UMD drive, REturn Shipping, and 90 day warranty. Contact Repairtech@playstationclinic.com
Oct 23, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
41 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
