Question about Philips 42MF230A/37 42 in. Plasma HDTV
Panasonic TD-50phd5 I had a problem today with the dreaded flashing red LED on the front panel. I found out it may be a bad fan, so I opened the unit up. All fans were working and the problem went away, so I closed it back up and rehung it on the wall. Now, I am getting a condition where the full screen displays the picture, but about 55% of the picture is perfect and 45% of it has some kind of blue artifact over it. With no signal input, 55% of the screen is black and 45% is a sky blue. What happened?? Thanks for any help you can provide
  • 8 Answers
SOURCE: tv will not turn on--- flashing red led
You will need to take the TV in for repair. The red light is the TV's way of telling you the protection circuitry has been tripped. There is most likely a problem with the power supply inside the TV.
Posted on Jul 13, 2007
SOURCE: 42PF9956/37 SHUTSDOWN...
HI, HAD THE SAME PROBLEM THE OTHER DAY AND PULLED THE PLUG FROM THE POWERPOINT FOR A FEW MINUTES AND THEN PLUGGED IT BACK IN....EVERYTHINGS FINE.. MUST HAVE NEEDED SOME SORT OF REBOOT OR LIKE REMOVING A BATTERY FROM YOUR PC, RESETS EVERYTHING..TRY IT, SHOULD BE OK AFTER THAT,,,GOOD LUCK
Posted on Jan 30, 2008
  • 77 Answers
SOURCE: Philips 42 in. Plasma shut down
The LED blinking 7 times is a code to tell the service tech what is wrong with the TV. From what I've read at other sites it sounds like there;s a good posibility that it is a power supply gone bad.
You probably should call a TV repair shop for assisitance.
Posted on Feb 01, 2008
  • 90 Answers
SOURCE: Philips 42PFL5332D/37B no picture no sound but blue led light on
power supply board is going bad
Posted on Mar 03, 2009
SOURCE: 42PF9966/10 - PHILIPS - UNIT NOT WORKING, NO PICTURE, PWR OK
Having the same tv and problem for a year ago.
I disconnect the main powercord from wall socket
and wait for 2 min. and connect again.
Problem solved. Its not a fix, but maybe it helps?
Posted on Nov 07, 2009
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
Panasonic TX-L42E5B blinks 3 times which board is faulty
When an abnormality has occurred to the unit, the protection circuits operate and set the unit to stand by mode. At this
time the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Fault maybe on the A board 3.3V SOS give me your email & i send you the full timing chart.
Apr 04, 2016 | Panasonic VIERA TX-L42E5B 42" LED TV...
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
2. Contents
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
My Panasonic PT-60Dl54J tv shut itself off and the power button is now flashing red 6 times. What has happened, how do I fix it?
This is straight from the service manual (I'm not sure what the problem is but it sounds serious):
8.2. Power LED Flashing timing table
When an abnormality has occurred, the protection circuit operate and cuts the power supply. At this time, the defective line can be
identified by the number of flashes (red) of the power led indication at the front of the unit.
NUMBER OF FLASHES CIRCUIT MICRO PIN
1 LOAD SHORTAGE 92
2 OVER VOLAGE 93
3 FAN SOS 94
4 MAIN 3.3V 88
5 LAMP DISABLE 61
6 GC3FM-IIC IIC
7 GC3FS-IIC IIC
8 GC3I-IIC IIC
9 COLOR WHEEL STOP 110
Dec 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Open Questions:
Philips 42MF230A/37 42 in. Plasma HDTV Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
