Question about Microsoft Office Professional 2007 Full Version for PC
Start menu my start menu will not work on windows 2000 pro, it stays pressed in when I click on it and stays stuck.
    Problem Solver:
  • 7 Answers
Hello! am Fabian,
if the start button you are talking about is that of your operating system. you may need to run disk maintenance on your system. run the check disk utility (using the command c:\>chkdsk /f on the commad prompt).
note that office professional 2007 can not run on windows 2000 pro, you need an upgrade to windows XP SP2(service pack 2).
i hope this information will help.
Posted on Sep 22, 2008
How to restart a pro line Intel sv.701
If you have Windows
Left-click START or the round blue Windows icon at bottom left of screen.
Or press the Windows key at bottom row of keyboard.
Left-click the white right-arrow symbol next to "Shut down".
This drops down a choice menu.
Left-click "Restart".
Now sit back and watch the magic happen.
Otherwise to shut down click the Shut down bar in Start window.
Or in case the PC freezes / hangs press "Power" button.
If an application hangs, stopping your computer, you can also try close down the app in "Task Manager".
Press Ctrl+Alt+Del
Wait until the Task Manager options window pops up on screen.
Left-click "Start task Manager"
Left-click "Applications"
Shut down the app then exit TM.
Reboot to refresh memory.
Dec 04, 2017 | Intel Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
How do you get out of safe mode?
Safe mode is normally manually activated by pressing F8 at startup. However if it is stuck, you can try disabling it from the system configuration menu:
If using Windows XP:
1. Start the machine and boot to the Windows desktop.
2. Click Start > Run
3. In the dialog box, type msconfig and press "Enter". This will bring up the configuration window.
4. Click on the "Boot" tab and in the lower left corner under "Boot Options", untick "Safe Mode".
5. Restart the computer.
If using Windows Vista/7:
1. Follow the same instructions as above, however when you click Start, just type msconfig in the search box at the bottom of the Start Menu and press "Enter".
Jul 19, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Volume control keys on MS comfort curve 2000 keybrd not working
Restart the HID Human Interface Service. To fix this problem yourself, follow these steps:
  1. Open Microsoft Management Console (MMC) snap-in for Services.
In Windows Vista or Windows 7, click Start, type services.msc in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
In Windows XP, click Start, click Run, type services.msc in the Open box, and then click OK.
  1. In the list of services in the Details pane, double-click HID Human Interface Service, and then make sure that the Startup type is set to Automatic. Then if not running start.
Worked for me J
Mar 28, 2009 | Microsoft Comfort Curve 2000 Keyboard
I want to install again the WINDOWS 2000 Professional and i can't do it because it shows a blue image and says that i've to put the win 2000 pro disk on the diskdrive and i put. when i go to the...
What is the boot order in the BIOS? Set that to 1=FDD 2=CD-ROM 3=HDD
While the PC is still on, put the Windows CD in the drive
Restart the PC, watch the screen for a prompt to boot from cd - press a key
The installation will start, you will need to choose where to install Windows
If you do not need to save any data, format the C: drive and install window there.
Follow the prompts the rest of the way through the installation.
You will need to enter the Windows License code at some point.
It is a good idea to change the regional settings to match your location and how you want the date and time formatted.
Most things should be detected and installed automatically, so you are safe to accept the defaults.
After about 45 minutes you will need to restart the PC and then you should be ready to enjoy Windows 2000.
Be sure to go to Windows Update and install all of the patches.
Good Luck and let me know how it goes.
~ Spoem
Mar 24, 2009 | Toshiba Portege 3110CT Notebook
I just installed xp pro and it keeps freezing
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Radion 9500
repeatedly tap F8 on first power on. don't hold it down. tap it.. use arrows to move up to vga mode. that should let u change. it wont work till u shutdown restart.
Nov 02, 2007 | ATI RADEON 9500 PRO (128 MB) Graphic Card
Microsoft Office Professional 2007 Full Version for PC Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
