Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
I have an old Hotpoint Top Freezer Refrigerator model CTF15ELD Serial # TL301428. Recently the refrigerator part is not staying cold enough and there is condensation dripping on the upper part of the refrigerator in the back inside under where the freezer cabinet is. Cold control is set on 5, refrigerator seems to be about 55 degrees. Freezer is working - freezing icecubes, etc.
  • Anonymous Sep 28, 2008
    I also have the same problem, Freezer is working fine but the fridge is what feels like room temperature.
  • 943 Answers
Hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Posted on Sep 25, 2008
Top freezer model: the freezer works but the refrigerator stays at about 50 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Hotpoint HTS18 Top Freezer Refrigerator
GE Hotpoint Top-Freezer model - freezer works but the rest of the refrigerator is not cold - even when we turn the cold dial up to 9. Model - CTX14C1TGLWH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 01, 2010 | GE Hotpoint Top-Freezer Refrigerator
Freezer has to be thawed out every 2 to 3 days. The refridgerator side isn't staying cool enough to keep milk from spoiling. It is a Hotpoint Model #HSS25GFTA WW and is only 2 1/2 years old. It is a side...
Could be multiple problems. First, check the freezer compartment and make certain that the freezer fan is running. This fan moves cold air from the freezer compartment to the refrigerator. If it's not running, inadequate cold air gets to the refrigerator.
Your having to defrost manually sounds like there could be a problem with the defroster circuitry; however, check out the fan operation first.
The fan should be at the top of the freezer. There is probably an access panel you can remove to see if it's turning. However, you should be able to hear it if it's turning.
If the fan is not turning, you will need to remove it and replace it.
Oct 11, 2009 | Refrigerators
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Freezer not getting cold enough
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
202 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
