Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Power Light blinking 5 times
I have a Panasonic PT47WX52F. Green convergence (Verical was distorted). TV was working but convergence issues. So, replaced STK 392110 bought from suburban electronics. The Green vertical line was straight and was glad to see that but the screen was not bright. During my convergence adjustments, TV went blank and error came up. It was flashing 5 times. Checked the resistors, they were right on the mark as they were supposed to be. But, I still went and replaced all the resistors. Still no improvement. Then I took the STKs out of the circuit and plugged the board with with no STKs. Still flashing 5 times. Then I replace with new STKs. But no improvement.
According to the service manual, 5 flashes is the IC 4011 (NTSC signal processing) which has nothing to do with the work done, convergence. The TV turns on for a few seconds and turns off, relay clicking is heard. . Any suggestions/comments are welcome
  • jaf024 Sep 29, 2008
    The power light flashes a few times and then the tv shuts off. What can I do?
Check the resistors near the
stk's. There are some reports that they get fried when the stk's fry....or the other way around. The resistor ratings are labeled on the resistors. 2.2, 82, 180 or something like that. Also check the board as you turn on the tv. See if any glow red.
Posted on Sep 28, 2008
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Tv has horz distortion lines while a green horz line rolls up then down turn off tv and back on and tv works ok?
Projection sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3d, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from www.TvRepairKits.com . It includes replacement parts,step by step guides, support, etc.
You can also read more about this on the tips page here on Fixya. Here is the link.
http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
May 19, 2012 | Mitsubishi WS-55511 55" Rear Projection...
How do I fix my Panasonic PT-53WX53 53 in. Rear Projection HDTV the power light blinks when I press the power button and it will not turn on.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Panasonic PT-53WX53 53" Rear Projection...
On the right side of the tv aprox.3-4 inches wide down verical its black. It`s like the screen shifted left??
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 23, 2011 | Hitachi 60SDX88B 60" Rear Projection...
It will turn on, but as soon as the bulbs light up, the tv will go blank and the red power light will start blinking.
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Panasonic PT-47X54 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT47WX52F
those are bridge connectors they stay attached to the A board and release from the D board. Just slide a small screw driver under the bridge on the D board side and gently lift up they will pop right off.
Sep 11, 2008 | Televison & Video
Pt 53wx53 convergence
Same here,sorry I can ajust all but it just wont come in perfect.
What is the problem.Will the sevice menu work?
how do you get it?
Dec 16, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
155 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
