Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer
Basement flooded and got the bottom of the washer wet
  • 116 Answers
Did this cause the machine to stop work? Did something get burn? If its just that it got wet - just plug it out and do not start using it right away give it some time to drip dry and if you know how open it up and have a look to make sure no water is inside.
Regards
Posted on Sep 22, 2008
On my top load washer when it goes into a spin mode everything is real wet at end of cycle and there is water running on the foorwater seems to be coming some where in the back and watwer doesn;t drain but...
Might be the seal on the pump itself. If water is coming from underneath the unit, more than likely it's the pump seal. Very common problem. You'd be better off replacing the whole pump and not just the seal. Less trouble that way.
Sep 04, 2011 | Frigidaire GLWS1349A Top Load Washer
My basement flooded and now my whirlpool washer is not working. What could the problem be? The belt is not wet and on. What could stop working from the water?
It all depends. If the water got into the control board, it is hard telling what it could be to be honest. How deep did the water get? Has it dried out yet? It is possible if it drys out, it may work. But, you have all those electrical wires and if they got wet, they all can be damaged. If it only was a little bit, you might need to clean the pump and motor out. Really, it just depends how high it got because it could be a number of things.
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F/ll blinking is there a switch in case of flood?
If you had a flood and any water got into bottom of machine, you have probably shorted out a motor control board. These board are either in the lower back right or front left corner bottom. A qualified service tech should be called to do this repair.
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Amana ALW480DAW top load washer 9 yr old
You're not done yet. The washer pump probably is leaking. Lots of basements being pumped out in this area as a result of the snow.
Jan 16, 2018 | Amana ALW480DA Top Load Washer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Washer Froze, Spin Cycle Sounds like Jet Engine
when it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Dec 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
We just had a flood in our basement and our Whirlpool Duet Sport HE front load washer is displaying F28 which I know means something electrical. Is there any way I can disengage the electronics to get the...
Unplug the machine. Remove the bottom access panel (three torx screws along the bottom). Reach up under the area where the door lock is and feel for a round door release mechanism. Pull down and the door will unlock
Jun 08, 2008 | Whirlpool Washing Machines
Washer does not spin
May want to check out the belt on the bottom. If it got wet, it may have stretched it out to wear it wont work. The tension is caused by the motor sliding in and out on a sliding system, which may have gotten a little rust in there. Make sure the motor will move somewhat freely and that the belt isnt stretched to much. Might be an easy fix. Good Luck!!! Jim
Sep 08, 2007 | Maytag PAV2300 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
