Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 52 IN.
When we turn on our tv. it shows an inverted pic. the color is fine but it looks like a big letter U or a horseshoe. We thought at first that it may have gotten hot or an appliance that i turned on may have shorted it out. does anybody have any idea what could be going on with our tv
  • 4,234 Answers
Please do not use the service menu for this problem. The service menu is essentially for matching replacement boards to the particulars of your set. Significantly changing values can cause more harm than good. The rpoblem you have described is due to a component failure. No amount of adjustment will "fix" this. There is a problem in the convergence and/or vertical circuits. Please get a detailed repair estimate before you do anything. Some measurements are required inside the set to determine the fault.
Keep us posted.
Dan
Posted on Sep 24, 2008
  • 57 Answers
You will need to enter the Service Menu and you can adjust this.
For the RCA D52W20 here is how you enter the service menu:
Turn the power off at the front panel, and then press and hold CH - and VOL - at the same time; after holding for about 8 seconds, the television will turn itself on in service menu mode.
Rca tv powers up has backlight no sound or picture replaced main board and inverter
I would check the input board for correct power supply input
check the blue 15pf 6kv caps near the output from the PSU to the inverter.
Aug 31, 2014 | RCA 46 46LA45RQ LCD TV
Hi, We have an RCA 27R410T that appears to have the ITC008 chasis. My son was watching the TV then the picture started to flutter and the color washed out. No more flutter but colors are washed out. Im...
Tv have video board problems.The tv video board main big colors inverter incoders IC it is dead.Must be replace and all those capacitors around IC should be tested and replace too.Fixed this problems before,but not as a CRT tube design for as a tv,but as CRT tube design for as a computer monitor.
Jun 15, 2011 | RCA 27R410T 27" TV
HDRCA 52" model R52WH77, the pic looks like a big U in the middle of the screen and it turns its self on after turning it off. Sound is fine.
A capacitor is building up power and then when there is too much power it discharges turning the tv back on without you hitting the power button. The tv will need to be repaired by a service tech however get a quote and then decide whether it is better to just buy a new tv. LCD's have dropped in price greatly.
May 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
All the sudden pitcher is bowed and colors are sepertated
This is convergence. First read FL231 fuse problem in tips and trick section to see if this may be the problem
Jan 22, 2009 | RCA HD52W58 52" TV
52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Oct 29, 2008 | RCA D52W19 52" Rear Projection Television
Need help.
You need the ITC222 convergence power supply board. You can get a new replacement board at the following link.
http://servicemanuals.vstore.ca/
Aug 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA BIG SCREEN TV - COLOR PROBLEM
If your TV is rear-projection system, it got problem in convergence board, may be few bad-solder connections.
May 30, 2008 | Audio Players & Recorders
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
115 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
