Question about Hitachi Televison & Video
LOST COLOUR: C29 F500DR The colour seems to have disappeared on my Wow by srs C29 F500 DR. I have a digital set top box attached. I cannot seem to restore colour. Any adjustment of the picture via remote control - scrolling through "Theatre" "natural" and respective settings does not help.
    Brigadier General:
  • 6,966 Answers
To my knowledge, a Hitachi Hitachi C29-F500DR is a 29incher Flat Screen CRT TV. A couple of ideas:
  • check if your version has a PAL/NTSC selector in the menu. Largely dependent on your region/location, switching to another color system would exhibit this problem. Try selecting the other to what it is currently using;
  • as in most TVs, there would be a color circuitry involved that uses a crystal. This crystal is responsible for establishing the color and at times do go bad.;
  • it may be an issue with the digital set top box, pls try using this box on another TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 22, 2008
  • 84 Answers
I suspect that you have connected via componet I would check the red green and blue cables
you may have lost a one of the colors but check the cables first
is it b/w on it's menus?
if it is you have a color element out
Panasonic dvd rv32 no colour
We had a similar problem - resetting the DVD to factory settings seemed to work for ours
Mar 17, 2012 | Panasonic Televison & Video
I have done the color convergence and the picture still seems to be a bit off and now the whole screen seems to lean down on the right side.
Is the static colour bent also? It shouldn't be.
It takes hours some times top set these things up.
Cover one colour up with a piece of card whilst setting another to the donor colour. Usually Green stays static for this purpose.
Hope that helps.
Dec 24, 2010 | Mitsubishi WS-65807 65" Rear Projection...
I can't seem to get the proper colour back
I unplugged everything from the wall outlet and Roger's box. When I plugged it back in the colour was much better.
Nov 15, 2009 | Insignia 42" LCD Flat-Panel HDTV
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
Sep 23, 2009 | Televison & Video
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black (no colour) printing setting Ebson Stylus CX4800
Ask to print,when printer screen comes up go to properties on the top right then advanced on the bottom right (it'll ask if you really want this --you do) then on the bottom left there is a box to mark for black and white only
Jul 31, 2008 | Epson Stylus C66 Photo InkJet Printer
Cannot select a lower bit depth in colour than 24 bit?
With better processors and large storage, higher color depth is the order of the day; however if you dont want higher color depth, you can convert the images after scanning. Ofcourse it requires an addl effort.
May 21, 2008 | Canon DR-9080C Path-Through Scanner
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
112 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
