Question about Roper RAX7244KQ Top Load Washer
Roper washer frozen drive?
During normal washing, the machine entered the rinse/spin cycle and stopped. I cant turn the basin by hand- seems like its frozen, and I cant find anything obvious jamming the works. Ideas?
  • 172 Answers
I would first check the lid switch and the plunger that pushes the lid switch. If both are good I would make sure the machine is washing properly. If the machine will not wash or spin you have a bad coupling. If the washer will wash then stop at the spin it is usually a bad lid switch, or transmission. The transmission will have a 5 year warranty. It is also possible that you have an object stuck under the main wash tub. You can remove the cabinet and look for objects or you can remove the wash basket itself. Good luck with your repair.
Mike
Posted on Oct 28, 2008
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
The washer tub on my Roper washer does not spin during rinse cycle. The motor coupling seems to be OK.
SOUNDS LIKE A LID SWITCH OR A BAD MOTOR OR TRANNY. I WOULD CHECK THE LID SWITCH FIRST
Nov 03, 2009 | Roper RAS8445KQ Top Load Washer
Washer tub won't spin. Belt is slipping. Drum seems frozen.
you might have a relay thats shot or the brake solenoid is shot. check both of those, it may fix your problem.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAX7244KQ Top Load Washer Logo
154 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
