1997 Audi A4 Logo
Anonymous Posted on Oct 11, 2011
Cant find the clutch reservoir on my audi a4 1.8 eastate r reg..
brian soufane
Level 3:
President:
  • Master 693 Answers
  • Posted on Oct 11, 2011
brian soufane
Master
Level 3:
President:
Answers
693
Questions
Helped
511776
Points
4903
The Clutch Master Cylinder is located on the firewall inside the engine bay, and usually next to the brake master cylinder as the brake and clutch pedals are usually very close to one another. The Clutch Master Cylinder is responsible for transferring the clutch pedal pressure hydraulically to the slave cylinder to release the clutch. You can tell when your clutch master cylinder is dying or needs repair when you depress your clutch pedal and it slowly sinks to the floor and does not return. Since the entire system is a hydraulic one, the master cylinder also has a reservoir that holds the fluid used in the clutch hydraulic system. If you decide to change the clutch master cylinder it is a good idea to also get a clutch slave cylinder at the same time, as both units typically fail around the same time. When replacing your master or slave cylinder, its always a good idea to flush your entire system to prevent water buildup or air pockets from being present when you are driving. Also always keep an eye on the fluid in your reservoir, dirty fluid may mean that the internal seals are allowing dirt and contaminants into your master cylinder.
  • High5inmofo Nov 09, 2011
    It runs off of the brake fluid reservoir, just went thru the same thing on my 97 a4....same fluid, same reservoir. If u look at the right side of the brake master cylinder reservoir, there is a black rubber hose running into the firewall, that's the feed for the clutch master cylinder attached to the clutch pedal, I just replaced that, that's how I know. How this wasn't too late.
2004 Audi A4 1.8t I cant change gears. Dead clutch pedal...is it the master cylinder? but I have a feeling it is the slave cylinder maybe even the disk. What would someone reccomend I replace?
Power steering reservoir is NOT linked to the clutch.
The BRAKE Fluid Reservoir (in plenum below windscreen) is shared with the Clutch Master Cylinder.
So, check the Brake Fluid Reservoir.
If that remains full, you can essentially rule out a leak.
If it is low (but hopefully not empty), that could indicate a clutch system leak, as it should feed off the reservoir at a higher level than the braking system (brakes are critical obviously, clutch is not). Either cylinder can leak.
If the reservoir is empty, you could have a problem with the brakes, and the clutch is just a symptom.
There are also mechanical connections between the master cylinder and the pedal, and the slave cylinder and the clutch. You can check the master cylinder to pedal linkage up under the dash.
Ware do i put clutch fluid
My understanding is that a common reservoir is used for both the brake and clutch hydraulics.
2helpful
Audi tt 2003 1.8T Brake warning light beeps and comes on when I go around a corner. Clutch pedal occasionally goes to floor when cold and does not want to return. Both these problems have happened at the...
hi, i'm pretty sure that you do have a combo brake/clutch system on the same reservoir. sounds like the brake fluid is low, when you take turns and the brake light goes on, that usually means low fluid sloshing away from internal reservoir sensor. audi and vw take DOT 4 brake fluid only, not DOT 3. You should fill to max level on the brake reservoir(located in front of the drivers seat/steering wheel in the engine compartment) and yes, take it to a professional shop, there maybe other problems in the brake/clutch system in need of inspection. hope i could help.
Where is starting motor on audi a4 p reg
The starter motor is placed on the right bottom side of the engine (on the passenger side), and it is mounted on the clutch case & cylinder block.
Where is the clutch slave cylnder resivior located on a 1989 audi 80
the clutch fluid reservoir is under the hood,mounted to the firewall next to the brake master cylinder.the 'lid' is sometimes retained by a bolt.
Just bought audi a4 tdi w reg cant input anything
try puling the fuse out of the back of the radio and then letting it sit for an hour then you have to push a sequance of buttons to put the radio code in so it will unlock
Clutch pedal goes to the floor on A6 2.8 P 1997
It's a hydraulic system on the Audi. Using a master cylinder (nearer pedal and firewall) and a slave cylinder (at clutch release bearing itself, or on side of tranny. Owner's manual should give location for a reservoir to check. Similar but smaller than brake master cylinder reservoir if that helps. The system uses brake fluid, and you either have a leak, a lack, or a loss of this fluid, and/or pressure to the clutch. Sounds like you need qualified service, these systems need REAL diagnosis before you start buying parts. ALso can be hard to bleed completely free of air after parts are installed.
1helpful
2answers
My Audi A4, will not allow me to put car in gear with clutch depressed and engine running If I switch of engine I can engage gears easily. If I place in reverse and switch on engine with clutch down the...
moselecm, Audi's transmissions are known for very late clutch engagement, so that part is normal - they're built that way and are not adjustable. To be sure it is really slipping due to wear and not just unfamiliarity, put the car in fifth gear at about 30mph and FLOOR the gas. If it's going to slip, that's when it will slip.
As for the fluid, it shares a reservoir with the brake fluid reservoir - take a look there at the fluid - what you see in there will be the condition that both the brakes and clutch are operating under.
Brake and Clutch System
If there's only one reservoir, then yes, they share the fluid and reservoir (my Audi is the same way).
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
