Question about Whirlpool RF378 Electric Kitchen Range
Old Beaumark electric kitchen range
I just bought a house with the above stove in it and we can't figure out how to use the oven It has mode buttons and the front right burner knob has the temperature markings on it but no matter what I do I can't get the oven to come on let alone figure out how to set the temp if it should. Each time I press a mode button and turn on the burner, the burner only comes on. Pleas help or I'm going to have to buy a new stove.
  • 2 more comments
  • caschwindt Sep 22, 2008
    I was hoping to find out how to use the controls, mode buttons etc. I will check the fuses but have to pull the stove out to do that. There are some instructions above the fuse panel but they are different from the ones on the stove.
    I checked the fuses and they are fine. I need to know how to operate the buttons and dials and how to turn the oven on and off and how to set the temperatures for the oven.
    It just says Beaumark with a sunburst type thing between the two words. I not able to find a serial number or any other identification, I pulled it out and checked the back, I checked inside to oven and inside the fuse panel. Nothing there. I'm guessing it's about 20 years old
  • caschwindt Sep 23, 2008
    I'm not trying to fix a microwave.
  • 2,071 Answers
HOW RANGES/STOVES/OVENS WORK
For a detailed Range/Stove/Oven illustration, click below.
Gas Free Standing
redarrow.gif Electric Free StandOld Beaumark electric kitchen range - redarrow.gif>redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarroOld Beaumark electric kitchen range - redarrow.gif= Gas Walloven
redarrow.gif Electric Walloven
Electric combination range/ovens are stoves that have both surface burners and an oven. Depending on their features, some electric range/oven units are quite complex. To understand how they work, let's look at the following areas:
The control panel
The cooktop
The area beneath the cooktop
The interior of the oven
The broiler
The back of the unit
click below for customer support;
http://www.beaumark.ie/catalog/contact_us.php
Hope it may helps you;
Regards,
Posted on Sep 23, 2008
  • 4,889 Answers
Try finding a manual here. If you dont find it you can request a manual and they will get it for you.
    President:
  • 1,952 Answers
Best you buy a new oven so ur old stove rerair is rare then its troble f or at time cost is more waste
Posted on Sep 22, 2008
    Sergeant:
  • 399 Answers
HOW MICROWAVES WORK Microwave ovens are complex and sophisticated, but they operate on a very simple premise. They warm foods and liquids using microwave-frequency sound, rather than a gas burner or an electric heating element. How microwave energy is produced Why some foods cook better than others Safe, quick, and inexpensive How microwave energy is produced Your microwave oven has a small transmitting antenna, much like a radio station or TV station might use. The microwave oven converts the electricity from the house into an extremely high voltage, which feeds the "magnetron, " which converts the high voltage into radio waves. The radio waves funnel into the cooking area of the oven, which makes the molecules in the food or liquid resonate (vibrate) wildly?which causes friction between the vibrating molecules?which generates the heat for cooking. Why some foods cook better than others Whether a food type is suitable for cooking in a microwave oven has a lot to do with the structure of the food--or the lack of it: Consider bread. It has an internal structure of air pockets. When the microwave gets all of the molecules in the structure vibrating at microwave frequency, the structures break down and the bread becomes tough and inedible if cooked too long. Now consider water. It has no structure. When the microwave frequency gets the water molecules vibrating, they rub against each other creating friction--then heat. Because they have no fragile structures to break down, foods with high water content tend to heat nicely in the microwave--including vegetables, soups, and so on. Safe, quick, and inexpensive Because microwave ovens use radio waves, rather than radiant heat, to heat food, they are considered to be quite safe. Also, they don't introduce anything unnatural into the food, and they are more energy efficient than standard resistance cooking devices. Q - My microwave seems to shut off every once in a while, what might be wrong? A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt. Use an old tooth brush to help clean off the grille area. Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food? A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything. A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay..... Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running. A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common. Q - My microwave went dead when I opened the door ( same problem as closed the door ). A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse. Q - My microwave is completely dead. A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. Q - The fan in my microwave oven is not running will this hurt my microwave? A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace. Q - My microwave blows the fuse inside itself as soon as I push the start button. A - Usually a shorted high voltage capacitor...see components section. A copy and tip from Prashanth: Description of problem (Maytag CMV1100Q) : Microwave stopped working while cooking. Replaced a 20AMP fuse. When the cook cycle starts, microwave makes a groaning noise and stops. It loses power since the fuse is blown. Solution: High-voltage capacitor shorted. Replaced it and microwave works fine. Its located behind the fan underneath the high-voltage transformer. Remove the vent fan hood Remove the display control panel by removing the screw Take pictures of all the connections behind the control panel. Unhook all connections Remove the connections to fan Remove the fan Remove the screws and connections for interlocking switches. Make sure the high voltage capacitor is discharged! Remove the high voltage capacitor and replace Retrace the steps and put everything back. Microwave works great now. Q - I burnt something in my microwave and now it is dead...help! A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that click on the link below for which u have the doubt http://www.applianceaid.com/micro.html
    Genius:
  • 1,447 Answers
Hi-
Whats the exact model of your stove?
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Sep 22, 2008
    Go to this link and look for the model then you can get or inquire about the manual for your oven
    click HERE
    Hope this help
    Brigadier General:
  • 5,158 Answers
Did you already check the fuse for the oven ?
Robert
  • Roberta Smith
    Roberta Smith Sep 22, 2008
    Look at the front of the stove where the control panel meets the horizontal part of the stove. is there a panel there... most stoves i've worked on have two round nuts that are threaded on by hand... also as some companies just have a lid at the very top where the control panel is that swings up.
    Fuse are usually easily accessable
    Robert
I have the Legacy model 3530-3630 gas/electric stove.....my problem is this: for the past few days there is what sounds like a fan running in the oven. This runs constantly whether I am using the oven...
This is the convection fan. My hearland range does this too, after power loss in the house. I cancel it by starting and then stopping convection mode. ie. hit convection (fan icon) start (running man) and then cancel (X).
Dec 27, 2010 | Heartland 3530 Dual Fuel (Electric and...
Can not work automatic clean cycle on Maytag range
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 05, 2010 | Maytag MER5775Q Electric Kitchen Range
Bought house with self-cleaning oven but no
There should be a standard that comes up when you turn it on. Mine has two options, 2 hours or 3 hours. Needless to say, the dirtier it is, the longer you should set it for! That said, I only use the minimum time for mine.
Jul 16, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Oven won't heat up to set temperature
IF THIS IS A GAS RANGE, AND IS USED ALOT, 4YEARS IS ABOUT THE LIFE EXPECTANCY OF THE IGNITOR FOR THE OVEN. IF THE IGNITOR IS WEAK, IT MAY NOT OPEN THE SAFETY VALVE. WITH A FLAT IGNITOR, IT REQUIRES 3.3AMPS TO OPEN THE VALVE. IF IT IS A ROUND IGNITOR, IT REQUIRES 2.8 AMPS TO OPEN THE OVEN IGNITOR.
IF THIS IS AN ELECTRIC OVEN WITH AN ELECTRONIC CONTROL, I WOULD SUSPECT THE OVEN SENSOR AS THE DEFECTIVE PART. AT ROOM TEMP, IT SHOULD READ ABOUT 1084 OHMS OF RESISTANCE.
IF IT IS A MECHANICAL CONTROL(WITH A KNOB) IT MAY BE ADJUSTABLE BY REMOVING THE KNOB AND INSERTING A THIN SCREWDRIVER UP THE SHAFT OF THE CONTROL AND TURNING A SCREW IN THE SHAFT TO CALIBRATE THE TEMP.
Apr 04, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool RF378 Electric Kitchen Range Logo
792 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
