Question about D-Link DFM 562E (dfm-562e) Modem
Intermittent hangs with high fax volumes
We use this modem for sending high volumes of faxes via a  3rd party automated software process and get intermittent hangs.   Is this Fax modem a reliable option, could it be the cause ? Any ideas on what else may be causing this ?
Thanks Steve
  • epic57 Sep 22, 2008
    Thanks, the 3rd party software indicates that the modem is busy and sits waiting. Testing of the modem independently of this (ie not at the same time) shows the modem to be responsive. We can usually send 1 fax successfully via the 3rd party software but then this occurs on subsequent faxes.
  • 928 Answers
Normally it would be as simple as queing and sending faxes but there are times when the problem is the line to the internet. If that goes very slow at some point during the send there is a chance that the modem will hang. Check if you are able to get on the internet with no problems for about an hour. How long do you notice the faxes going before it hangs. Also which actually hangs the third party software or the modem itself. You can test the internet by downloading a file see if it hangs up or becomes very very slow.
Posted on Sep 22, 2008
  • Thomas Lim
    Thomas Lim Sep 22, 2008
    Check on the software if you have an option to delay or have timed delays between singular sends. Meaning send 1 wait 10 seconds then send the next and so on.
How I can receive fax through computer with HP1312?
Hi a barati75
A fax transmission is an analogue communication that was possible on a computer with the old technology of Dial up Modems, which accessed the internet by dialling like a landline telephone. The Broadband Modems (or Modem/Routers) in widespread use today have an 'always on' internet connection and, therefore, no dialling is involved in internet access using them.
You can send a fax by dialling out on the All-in-one printer's telephone number pad. Receiving a fax automatically requires you to have the All-in-one printer's Transmission/Reception Settings set to 'Automatic'.
This fax setup requires the printer's fax cable to plugged directly into an empty Telephone Line Socket on the ADSL filter that plugs into your Telephone Wall Socket and has inputs for your Modem (or Modem/Router) and a Telephone line. If, as is common, your ADSL Filter only has a single Telephone Line Socket and you also require a telephone to be plugged into the same socket as well as the Fax Machine component of your printer, then a Telephone Line Socket Doubler must first be plugged into the Telephone Line Socket of the ADSL Filter which then receives the Fax Line into one socket and the Telephone Line into the other. Please note that every Telephone Socket in the building sharing the same circuit/telephone number must also have an ADSL filter between it and any telephonic device (Telephone/Fax Machine/Answering Machine/Stock Control linked EPOS (Electronic Point of Sale) System/Card Payment Processing Machine, etc.), in order to enable both Computer Internet Data and Telecommunications Data to share the same line without conflict.
Your question asks whether a fax can be received "through" the computer. The above description enables your printer to send and receive faxes 'independently' of the computer while simultaneously providing the computer with printing, scanning and copying functions. For faxes to be sent and received via the computer, software is required. The simplest and most efficient of which is Efax (Electronic Fax (available from www.efax.com) and other similar software available from a variety of suppliers. This software enables the user to send any document or image stored on the computer by fax (without first having to print it) and to receive faxes, at any time, in the form of attachments to e-mails that the software opens, usually as a non-editable PDF or other similar secure Document Format. Faxing a physical document via Efax requires the user to scan the document and save it on the computer first, before sending it.
A combination of a Standalone Fax function setup using ADSL Filters and Socket Doublers + Efax gives the user optimum flexibility in sending and receiving faxes.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment/Clarification Request to this Question.
Thanks for using FixYa
Sep 15, 2011 | HP LaserJet CM1312 All-In-One Printer
Tip
How to Send a Fax with Microsoft Windows 7 Note for you to use the built in...
Note for you to use the built in "Windows Fax and Scan" option to send faxes you will need to have a dial-up modem installed in your computer.
1. To access the software click the "Start" button and in the "Search Programs and Files" box type "Windows Fax and Scan".
2. Next click on "Windows Fax and Scan".
***Note Will Finish The Setup Process When I Get To My Computer With A Modem In It***
on Jul 28, 2010 | Computers & Internet
HI, I CAN SEND MY FAX TO THE OPPSIT PARTY BUT I DONT RECEIVE ANY FAX, WHEN THE PARTY SEND ME, AS THE PARTY GET THE REPORT AS WE HAVE RECEIVED THE FAX,,,,,,
Please be sure that you have the fax line in the correct jack on the back. Some of the HP modems will actually send a fax if you plug the telephone cord from the wall into jack that is supposed to have a telephonep plugged into it. On the back of the 1522 there are two phone jacks, the upper one is where the cord from the wall plugs in. Also ensure that if you have DSL service that you have a filter in the line for the modem.
Mar 03, 2011 | HP LaserJet M1522nf Multifunction Printer...
How do I hook up an HP v40 to my PC and a cable modem so that my FAX works?
You probably need to hook up to a landline telephone line, too. Or, you can use an "e-fax" service that lets you send faxes via internet. Basically, they would send your fax as middleman to the recipient. Windows Vista except Business version) does not have inherent fax support like Windows XP and Windows 7 Professional. And programs such as WinFax did not upgrade to Vista and 7. But, your fax modem should have come with some faxing software.
You put in modem card and then run telephone line to back. You can usually run a line to a telephone from the 2nd connection on the back with the telephone symbol below it.
Hope this helps you a litle.
Nov 20, 2010 | Computers & Internet
DFM 562IS (DFM-562IS) Modem: SIR PLEASE SEND ME ITS ALL FEATURES.......
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
K56flex
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
Does Windows 7 have the ability to send and
Well Yes, if you have a Modem, You can connect a Modem & then one can get software that you can use as a Fax machine. Also I believe there is a Built In Fax software too. However I recommend a third party setup. There are lots of really good FREEWARE Fax programs. Ensure they work with Win 7.
Feb 05, 2010 | Office Equipment & Supplies
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
Can I send a fax from my computer via the HP LaserJet M1522nf?
Yes you can send fax from computer.You need one dialup connection with Fax modem. then you need fax software. there are many software availble on the net . One is Mighty Fax. you can download it from the internet and many other you can search in google.
Sep 17, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
Broadcast Fax Sending
Change the resolution to STANDARD. This will cut your send times by 50%
Sep 06, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
How do I fax?
Sending a fax from your computer requires a fax modem and that your operating system be configured to allow you to send and receive faxes.
to send from fax software
step 1 Prepare the document that you want to fax. Step2 Prepare a fax cover sheet, if desired. Step3 Open your fax software - such as Microsoft Fax or Microsoft Exchange. Step4 Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item. Step5 Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed. Step6 Indicate whether you wish to send a cover sheet. Step7 When asked to attach the file, follow instructions to attach the file that you want to fax. Step8 When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine. Step9 When the connection is made, the fax will be sent. To Fax From Your Word Processing Program Step1 Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software. Step2 Open the document that you want to fax. Step3 From the File menu, select Print. The Print window opens. Step4 Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print. Step5 You will be asked to provide the recipient's fax number and other assorted information as with a fax program. Step6 The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
Aug 26, 2008 | Computers & Internet
D-Link DFM 562E (dfm-562e) Modem Logo
121 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
