Question about PfaFF Hobby 4260
Pfaff Hobbylock 776
I have lost the manual and am having trouble setting the tension. what are the basic settings please????
The best I can say is to change all your threads to different colors and get light colored material. Start with tenstion for all set to N - normal and experiment from there. Change one thread's tension at a time, sew a long strip and check out both sides and adjust as needed. Remember to start with new serger needles and a oiled machine. I'm not an expert - I just have had a serger for 15 years.
Posted on Sep 26, 2008
I have a 776. Start at the left dial set each of these onto 3 then the right hand ones onto 2.
Posted on Nov 17, 2008
  • Gisela Tilch Jun 13, 2013
    i just got a 776. Did not realize how old it is, but it is well serviced. Do you like yours? thanks for any input, Gislea
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Jun 14, 2017 | PfaFF Sewing Machines
Pfaff hobbylock 776
it would be a good idea to have the pedal and the machine both checked. only a sewing machine repair shop can tell you what the problem is.
Jun 24, 2013 | Sewing Machines
I need a manual for a Pfaff Hobbylock Serger 4762, where can I find one
I can't find a manual for this model, however there is a general hobbylock book http://sewingonline.co.uk/library/know-your-pfaff-hobbylock.html which would certainly be a good start.
You may find best source is to contact Pfaff locally and source it from them direct.
You could also try www.diplodocs.com, I can't see this manual but if you go through similar model numbers manuals you may see one very similar. Overlockers/Sergers are very similar in many ways so once you've mastered one, the next one is pretty straight forward. Four tension knobs, 2 needles and 2 loopers is the norm - to get a three thread stitch you just don't thread one of the needles. Tension adjustments alter the stitch formation, and you should have a stitch length knob on the right side of the machine along with a flywheel and if it has it, differential feed (which controls the feed dogs so you can stretch, or compress the fabric as it goes under the foot).
There are some good general how to use a serger books in the marketplace too which should help. Threading up, many machines have a diagram inside the front flap, colour coded dots on the knobs, eyelets and loopers. And oiling points are often marked on this diagram too. But basically oil the two loopers where they slide/move on another metal part. Some good info here too http://sewing.about.com/od/sergersoverlock/Sergers_Overlock_Sewing_Machines.htm
Hope this assists you a little.
Apr 18, 2011 | Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
I have a hobbylock 776. The square box on the shaft that holds the needles is broken. I think the holes for the screws are stripped. I believe it is the needle bar. Can not find a part.
You will need a new needle bar. Call your local Pfaff Dealer, as this part is only available from them (if at all). The needle set screw holes could possibly be tapped and fitted with different screws as a last resort, but I wouldn't count on it.
Jan 02, 2010 | Sewing Machines
Where can I buy a needle bar for a Pfaff Hobbylock 776?
If you email me your location I can supply you with a new needle bar.
sewingmachines@gmail.com
Jul 04, 2009 | PfaFF Hobby 4260
I am looking for pfaff hobbylock 786 serger manual do you know where I can get one?
ISBN 0-8019-8192-1(hc)? or ISBN 0-8019-8191-3(pb) by Naomi Baker & Tammy Young - "Know Your Pfaff Hobbylock" covers Pfaff Hobbylock: 797, 786, 784, 783 - Great book. This book is more helpful since it has detailed info pics in color- 182 pgs, @$3.00. Lists parts, projects, etc. The 786 manual has errors, 35 pgs. not detailed as the book above. Good luck! Fairlyart
Mar 12, 2009 | PfaFF Sewing Machines
Need a manual
Go to
manuals.pfaff.com/
and type in your model number, click "search"
and it should be coming up.
you can download it for free
but you might need adobe reader to read it
Jan 24, 2009 | Sewing Machines
Sewing Machines Logo
1,072 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
