Question about Epson Stylus CX4200 All-In-One InkJet Printer
I have a epson stylus photo r200 do i need all colors to print just black and white?
Printer
  • trowa2469 Mar 10, 2009
    there really is no way to print a single black and white page without replacing all other cartridges?
    Genius:
  • 1,447 Answers
HI-
Yes you need all the ink cartridges filled or they should have ink in it. That's one feature of epson printer to prevent air to clog nozzles.
Hope this helps
Posted on Oct 18, 2008
I CANNOT PRINT BLACK ON MY EPSON STYLUS PHOTO R200. All other colors print. I have replaced all the cartridges. This is my forth attempt at trying to contact you people. CAN YOU HELP ME?
this issue may have several causes:
1. make sure that you've removed the yellow ribbon from the top of the cartridge before installing it. it is there to keep the ink fresh before it's installed and has to be removed to enable the ink to flow into the print head. (not all epson cartridges have this ribbon though)
2. check all the settings in the printer driver or simply remove the current driver completely and reinstall the latest driver you can find on the epson site.
3. the black print head may be clogged. in this case, performing cleanings will help, possibly several cleanings are necessary
4. there may be a faulty connection between the printer's mainboard and the print head.
5.there may be an electronical problem with either the print head or the mainboard.
in the last two options it's better to let a professional technician look at it.
Mar 08, 2010 | Epson Stylus Photo R200 InkJet Printer
Epson stylus photo R200 status monitor in Windows 7
The epson R200 isn't supported in Windows 7. That's why the status monitor doesn't work.
Dec 28, 2009 | Epson Stylus Photo R200 InkJet Printer
I have an Epson Stylus Photo R200 that will not print
i am not sure where you are leading, but I assume you want to print with the black without changing the colors. No, you are not able to do that. If the colors require replacement, you have to change them before you can continue to print.
thanks
Aug 15, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 Can I print envelopes, if so , how?
check the program on the computer on disk and see if it will tell you anything
Mar 20, 2009 | Epson Stylus Photo R200 InkJet Printer
Inaccurate color printed
Check the color profile settings for your printer. Also, make sure your not using any kind of draft mode. Are you using refilled cartridges or off-brand ink?
Dec 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson photo r200
Sadly, if only one cartridge is empty, an Epson printer won't print. But, you can bypass that by using a chip re-setter. They have them in refill stores. By using a chip re-setter, you assign a new serial number to your cartridge, thus "fooling" the printer you have put a new cartridge in. Then, you don't need to refill all the cartridges.
Sep 09, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 - print with black ink only
Nope.....
Epson will not print unless all carts have ink in them to some degree. If the light is on for any reason, printing will be halted.
For future reference, once the color carts have been replaced, you can set the printing defaults to print in either gray scale or BW only. Keep in mind that Epson printers tend to mess up if you don't use the ink at least once a week.
Aug 01, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson stylus photo r220
Open the printer Properties, Under quality there should be a box
that you can check (print in greyscale) or (print in black & white).
You have to remembe to uncheck to print in color.
Feb 04, 2008 | Epson Stylus R220 Photo Printer Color...
Epson Stylus CX4200 All-In-One InkJet Printer Logo
416 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
