Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Are there parts available for grass hog x p grass trimmer
Black and decker 14" Grass Hog x p grass trimer
  • jacquepierce May 11, 2010
    do you have to buy a new spool string or can you just buy the string and reload the spool
3 Suggested Answers
darth yoda
  • 4 Answers
SOURCE: Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
gearbox!! get rid of it
Posted on May 29, 2009
  • 133 Answers
SOURCE: how to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Posted on Apr 21, 2010
  • 18 Answers
SOURCE: parts for Black & Decker 14" Grass Hog Xp
Easily, the best place and discounted parts place for this Black and Decker trimmer is eReplacementParts.com
Posted on Oct 06, 2010
Electric black and decker 14 grass hog won't start
spray the contact area on the weed trimmer with some contact cleaner WD 40 will work also
Mar 30, 2015 | Black & Decker Black and Decker & Grass...
How to rethread spool on black and decker grass hog cordless trimer
with fine file , refurbish male threads.
determine the female threads with magnifying glass to determine damage to female threads. female threads can be repaired with a die from OSH or H/D. ask for help to find the right thread pattern or take them both to the hardware store to get the right die
May 29, 2014 | Black & Decker 14" Grass Hog Xp...
I need a new spring to replace the lost one that makes the spool advance. Its a Grass hog that is a few years old. Not battery powdered, but electric. Can yoy tell me where to buy one or what size...
They have upgraded the old string heads (type 1) to a new string head (type 2). They say type 1 is no longer available. Please see part numbers 20 & 21 in this 14" Grass Hog parts breakdown diagram. The new string head is relatively inexpensive. If you don't want to get one, could I suggest you take the old spring (if you have it) and match it up with possibly a new spring at the hardware store. Sometimes you get lucky! Here is the parts diagram for it. Hope this helps!
http://www.ereplacementparts.com/black-and-decker-gh1000-type-grass-hog-trimmeredger-parts-c-4167_9518_9532.html
Oct 30, 2010 | Black & Decker 14" Grass Hog Xp...
Parts for Black & Decker 14" Grass Hog Xp Trimmer/Edger
Oct 06, 2010 | Black & Decker 14" Grass Hog Xp...
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
I can not get my grass trimer Bolens Bl100 to keep running when I press the trigger down it dies
clean the carburetor. if the diaphras in the carb feel stiff id get a carb kit. also check the fuel filter as well.
May 03, 2010 | Black & Decker 14" Grass Hog Xp...
How to restring back and decker grass hog
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
Auto feed will not work
It's cheapest to buy a new one. I had that problem last year.
Apr 28, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
1,325 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
EugenesDIYDen
EugenesDIYDen
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
