Question about Yamaha RX-595 Receiver
A/B speaker buttons
It seems like my A/B speaker buttons are not working.  sound comes out of both A and B speakers even if the button is on the off position. please help if you can it is driving me crazy.
thanks- liz
5 Suggested Answers
trintek
  • 111 Answers
SOURCE: Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Posted on Nov 16, 2007
SOURCE: Main speakers A and B not working...
Two possibilities for the no sound on the main speakers:
1) May be caused by the lack of the pre out main in jumper on the back of you reciever.
2) Check to make sure the -10db selector is not stuck between positions.
Posted on Dec 27, 2007
  • 4234 Answers
SOURCE: No sound to speakers with power on
I can not help much without the make and model as these units vary quite a bit. Please update this with that info. Also, do you hear a click when you turn on the set? You should here one followed a few seconds later by another. Please update this and I'll get you some possibilites and some things to try.
Thanks,
Dan
Posted on Jun 06, 2008
SOURCE: Cant Hear Dialogue Over the Background Sound
I had the same problem, first you can download the manual online to see how to reset the speakers. next, make sure you have true digital audio input with a fiber optic or like connector. you should see little LED symbols of r/l/c/w/rr/rl etc. If you just see R and L, it is not getting a true signal.
But what worked the best was getting a better, devoted, CENTER speaker, not just a speaker in the center, but one devoted to dialogue.
good luck
Posted on Jul 28, 2008
SOURCE: Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Posted on Apr 19, 2009
Want to use my current speakers with a new surround sound system. Current system is 5.1 channels, rated at 100w per channel @ 8. Ohms. New System is rated 145watts, 5.2 channels at 6 Ohms. Will b ok?
Hi Ronald.
8 Ohm speakers will work just fine as replacements for the
6 ohm speakers. When fitting speakers you need to consider
The power handling capability. The impedance and the frequencies
involved. Power handling is expressed in wattage ie 100W.
Unfortunately this can be expressed in rms, max or peak music. The rms value (root mean square) is the only really relevant figure as this is the continuose handling power at 1 KHz. The impedance
is the resistance that the amp sees but is not a dc resistance and
varies with frequency. The lower the impedance the more power
will be drawn from the amp. In the event of a short circuit across
the speaker the amp will try to deliver infinite power into an infinitly
small load in an infinitesimal amount of time and will self destruct.
Using an 8 Ohm speaker draws less power than a 6 Ohm speaker.
Connecting speakers in parallel; results in the impedance beingreduced. For example two 8 Ohm speakers in parallel will result
in a 4 Ohm impedance load but in series will be 16 Ohms.
Incidentally the the .1 (5.1) is the sub woofer which only has
to handle the bass frequencies, a small percentage of the
amplifiers overall frequency response..
Connect your speakers and then power up the amp last
after double checking there are no shorts on the speaker
cables.
All the very best from Vintie.
Jan 07, 2017 | Audio Players & Recorders
Can't get my Kenwood VR715 receiver to go into the Select a speaker system to see if speakers are turned on. Followed manual instructions and can't get in. Any Suggestions.
Try resetting the unit by unplugging the unit from the wall, then plugging it in again WHILST holding the power on/standby button in. This should reset the system. If not:
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 06, 2017 | Kenwood Audio Players & Recorders
Tv sound not working, even with soundbar.
Is the sound muted or switched off in the menu. Try resetting the set to factory settings.
What make and model is it?
Apr 14, 2016 | Audio Players & Recorders
I have a Rowe R80 jukebox and after moving it it has no sound through the speakers I am in New Zealand
Well, in addition to all the fine suggestions that are here, I would like to add the simple and easy things that may have happened during the move.
IF YOU ARE NOT GETTING A LOUD POP WHEN THE MACHINE IS POWERED ON.......
1) Make sure that the wires on the terminals below are still connected to the screws. There is one ground and one each for left and right. The lower the tap the lower the (max) volume of the jukebox.If they are not connected there will be no sound.
There is a jumpers on the terminal strip where the volume control connects. Make sure that these connections are correct and tight. Also make sure that the jumpers did not fall off.
If you are getting the loud pop in the speakers when the power is turned on .....
Check the plug on the side of the mechanism, just below the back of the tone are.(looks like a little tube socket) Check to see that it is connected to the mech and the CORRECT PLACE on the amplifier. It mat be possible to have this end in the wrong place. bf77613e-82a3-4e37-b8fe-cc80f4d4dbcb.jpg
Check all all your connections against the pic.
I hope this was helpful.
Mar 24, 2014 | Audio Players & Recorders
Hi,Just purchased 2 antec gain Bluetooth receivers type bxr 100. Operating instructions are not included. Maybe it's just me, but i'm not succeeding in getting them to work. No lights at all when they
Make sure that the unit is fully charged by a micro USB the light on it will be red until it's fully charged put phone in search mode and press the center button until the light flashes red and blue after the phone finds it you should have an option to auto pair when it's not in use it will turn off when paired and working pressing either track button will start the music player then just play with the buttons and see what it does you can stop anything from the phone controls
Mar 18, 2014 | Antec BXR-100 Gry Audio...
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
May 28, 2011 | Audio Players & Recorders
Front two speakers not working at all
Hit the the speakers A/B/Off button on the receiver. If you plugged the front channels speaker wire next to the center channel on the back of the receiver make sure its showing B. If you plugged them in the banana plug part, make sure its showing A.
Apr 12, 2007 | Audio Players & Recorders
Sound problem with JBL Creature II
I had a problem with the speakers not working properly. The green lights lit, but the amount of sound coming from the speakers compared to that of the sub was much lower.
I decided to take it the speakers apart.
I found that the magnets on the speakers had moved forward slightly in the plastic cage they sat in. I pushed them back as far as they would go, and Hey Presto! working again!
I hope this helps someone!
Feb 23, 2007 | JBL CREATURE II Computer Speakers
Yamaha RX-595 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
