Question about Lexmark Office Equipment & Supplies
My printer is not communicating with my computer. I just got a new computer and I have tried restarting my computer and unplugging the usb but nothing works. I need to know what i can do to get my printer to communicate with my new computer
    Sergeant:
  • 305 Answers
As it is a new computer, have you tried uninstalling the printer software and start again. install the software as you did the very first time, this may clear any incompatible issues you may be having. remember to use the uninstall program which should in the same folder as the printer program (usually C://Program files) and then look for the lexmark folder. once you have fully uninstalled, reinstall. alternatively, insert your install disc that came with printer, select set up and you may be offered options of Modify, Repair or Uninstall.
hope this helps
Posted on Sep 21, 2008
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Printer unable to communicate with computer.
    Are you using the wireless network printer function or is the printer connected by a USB cable? If you are using the wireless network, launch the printer's Wireless Setup Utility and run through it. (Check for problems with IP, signal strength etc.)
    For USB, try resetting the printer (unplug it from the wall for 10 seconds). Check that the computer is looking for the printer on the correct port. Click Start > Settings > Control Panel. Double click on the Printers folder and right click on your Lexmark printer. Choose Properties then click on the Ports tab. Check that one of the USB port options is checked. (If you have a newer OS, Start > Devices and Printers and then right click on the printer.) Also try a new USB cable and a different USB port. If you have a print server or USB hub, try a direct connection.
    I hope this helps.
    Apr 22, 2010 | Lexmark X3350 All-In-One InkJet Printer
    Port not recognized - printer and computer do not communicate
    unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
    and that should solve the problem
    Jul 20, 2009 | Lexmark X3650 Printer
    Lexmark X8350 "communication not available"
    I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
    Jun 02, 2009 | Lexmark X8350 All-In-One InkJet Printer
    No communications computer to printer
    With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
    To fix a fouled install:
    (1) Uninstall the Lexmark drivers in Add Remove Programs
    (2) Shutdown the computer
    (3) Disconnect the printer from the USB port
    (4) Restart the computer
    (5) Run the Driver Installation software
    (6) Cancel ALL attempts by windows to auto install the printer
    (7) When the software asks for the printer connect it and continue
    Jan 21, 2009 | Lexmark X75 MF All-In-One InkJet Printer
    Printer won't print says USB is not hooked up
    Correct communication problems between the printer and the computer.
    • Remove the USB cable from your printer and your computer. Reconnect the USB cable to your printer and your computer.
    • Turn off the printer. Unplug the printer power cable from the electrical outlet. Reconnect the printer power cable to the electrical outlet, and turn on the printer.
    • Restart your computer.
    Aug 19, 2008 | Dell 946 All-In-One InkJet Printer
    Lexmark Z645 Printer
    i have a problem of Lexmark Z645 Printer i want a software of this .
    Feb 09, 2008 | Lexmark Z645 InkJet Photo Printer
    Printer and computer not communicating
    sorry my printer is lexmark 1200 series, tried restarting,unplugging usb, power supply to printer but keeps just sayin printer not communicating with computer
    Feb 09, 2008 | Lexmark All-in-One Printer with PictBridge
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
