The volume went out and I had the problem fixed by a computer techinian. He commented that he had to reinstall the driver. The volume was working fine then all of sudden it has stopped working again. How can I fix the problem? My computer is a gateway laptop model nx570x. Please help. My name is Rhonda VanDyke drmavan_4@hotmail.com
  • 20 Answers
Right click on the MY Computer listing on the start column. Now click on properties, then click on the hardware tab. Now click on the Device Manager button. In this list under Sound there my be a yellow sign w an exclamation point in it. click on this sign and read to see if the device is working. If not, then try to reinstall the driver as the message says. Reboot the machine. if the problem goes away so be it. If not, then the problem is more serious and will probably tech work. Check back with the Tech and see if all he did was reinstall the driver. If yes, then it seems that a recent program installed or something else has messed with or is still messing with the driver or it's the wrong driver period. Also the sound card section of the MB could be defective. If all else fails, all I can recommend is you try to reinstall windows or have the tech fix it again and get a serious answer to what the problem was and how he fixed it. He should have told you in the first place.
Posted on Sep 22, 2008
I had reformat my PC .. because it wasn't working out .. i was not able to save all the drivers .. as in ALL .. when i finished reformatting my PC .. I discovered that it had no sounds at all .. My PC is...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 13, 2011 | Computers & Internet
My sound went out on my computer. At first it sounded distorted. like talking through a helium balloon and then it just stopped working all together. My sound is on and everything is plugged in. And the...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 18, 2011 | ASUS Computers & Internet
I ask for a answer to why i dont have sound on my computer ,if i listen to a audio tape or music or play a game i have no sound.i went in my panel box but my volume control wont move.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
also
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 26, 2011 | Computers & Internet
My computer have no sound
Check the volume control of your pc if the volume was set to mute. Click start, all programs, accessories,entertainment and click volume control. Check the pc speaker and master volume it must not be muted. If it muted un-check it. If its not muted then your problem is the audio driver. You have to reinstall the audio driver of *********** board. Send me the model of laptop so I could send you the appropriate sound driver. Just send it by posting fallow up comment for this problem. Thank you.
Dec 07, 2010 | Acer Computers & Internet
I have a HP Pavilion dv7-1232nr, the mute button and the wireless button on the top touch pad has quit working along with the volume slider. Any suggestions?
My mute button on my hp pavilion dv7-1262us stopped working after I updated my IDT High-Definition Audio CODEC through Microsoft update. The volume worked but the button stayed orange. I went to Device Manager- Sound,video and game controllers then IDT Audio CODEC. Click the Driver tab then click the Roll Back Driver button. This rolled the driver back to an older version but it fixed the problem. This is a Vista machine. Hope this helps.
Mar 06, 2010 | HP Pavilion DV7-1232nr Notebook
My computer is an Acer 5536 and I have two problems. The first one is with my sound. It has an x on the volume icon, but when I click to change it, it says sound devince not installed. I went to the device...
you got it over night huh? i have a few solutions for you: 1. sound-try to reinstall your sound card using its driver disc. 2. other problems that you have are very seriously if you got them just like that but try this to get rid of them- use system restore and restore your computer to earliet date that you have offered. this might help you but it cause reinstalling the programs and updates that you have installed on computer since that choosen date. if that won't work i HIGLY recomend you to reinstall your windows!
rate and comment and thanks for using fixYa!
Jan 07, 2010 | Acer Aspire 5536-5224 Notebook
Volume control doesn't see the installed audio card or its driver
first of you cheak how many bits xp you use & your drivers driver are how many bits actully xp are two types XP32 bit & XP64 bit & drivers are also two types
Sep 19, 2009 | Dell Dimension 2400 PC Desktop
Volume stuck on mute
I don't think you're stuck on mute I think you're having problems with your sound card. Go to device manager; if there is a yellow or red sign on sound then right click and try reinstall driver. Let me know if you have any questions. Pls rate this solution.
May 07, 2009 | Dell Latitude D600 Notebook
Device driver problem
Hold in volume + and connect the goGear to computer - after continuing to hold the volume + for 10-30 seconds, Windows should reinstall the missing drivers
Apr 20, 2008 | Philips SA5125/37 MP3 Player
Driver recovery
Its not possible to recover your drivers since u formated the harddisk, you have to reinstall the drivers provided with the webcam
Feb 28, 2008 | Computers & Internet
Open Questions:
C@'' 1 877 778 89 69Avira Antivirus Support Helpline Number? USA 1-877-778-89-69 Avira Antivirus Support Helpline number is straightforward to use. Avira Antivirus Support phone number is open twenty four hours daily and seven days per week.Avira Antivirus support Helpline Number's agent will assist you with remote help.Avira Antivirus Support Helpline Number 1-877-778-89-69 is one of the most promosing and helpfull number of any Antivirus issue's.We are open 24*7,ready to solve your problem with just a TollFree call:-1-877-778-89-69 .Our expert team finding your issues area and solve the problem in faster and easier way.We are Happy To Help You.We are Avira Antivirus SupportUSA.A single call will change your life.just dial:-1-877-778-89-69. For any question or help:-1877~778~89~69. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number.
Apr 25, 2017 | Avira Computers & Internet
Computers & Internet Logo
53 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
