Follow these steps to scan using HP software:
Step one: Load the item to be scanned
Make sure that the product is connected to the computer.
Turn on the product.
Load the item in the document feeder tray or on the scanner glass
TipLoad the following items in the
Single items
Items that are not easily damaged
Multipage, single sided items that you want to scan into one file
Load the following items on the
scanner glass
Single items
Items that are easily damaged, such as old documents and photos
Multipage, double sided items that you want to scan into one file
Option one: Document feeder tray
Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
Adjust the width guides to fit the item.
Option two: Scanner glass
Open the scanner lid.
Place
the item with the print side down on the scanner glass. For the correct
position, see the engraved guide near the corner of the glass.
Close the scanner lid.
Step two: Scan the item
Use one of the following methods to open the HP scan window:
Double-click the HP scan icon (
) on the Windows desktop.
NOTE:If you have more than one HP product installed, double-click the HP scan icon (
) for the product you are scanning with.
Click Start
), click All Programs
, click the HP
folder, click the name of your HP product, and then click HP Scan
Click the scan option for the item you are scanning.
NOTE:Depending on your HP product, you might not have all the following scan options available.
Save as PDF
Use this setting to scan text documents that are not editable. Use the
Save as Editable Text (OCR)
option to scan text that you can edit.
Save as JPEG
Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
