Question about Maytag EPIC MFW9700S Front Load Washer
Maytag washing machine
Hot water cycle not working
  • JMH5530 Sep 21, 2008
    i am still having the same problem and Im trying to get a hold of sears tech he was helpful but the session ended on us while looking for a part.
  • 116 Answers
If the hot water is not cycling then you have a bad solenoid (coil),strainer is clogged or no power to the coil. Check the harness to make sure that the connector is firmly secured to the coil
Posted on Sep 21, 2008
Washer will not proceed to rinse cycle
Maytag leaks This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 14, 2013 | Maytag Neptune Washing Machines
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag clothes washer won't fill with hot water
Then you most likely have a bad hot water valve. On Maytags the valve is one combo unit for both hot and cold. Maytag didn't change that much for a number of years, so you may be able to salvage one out of an old machine somewhere and fit it in -- that's what I did when my wife's Maytag did this.
Dec 30, 2009 | Washing Machines
After wash cycle still has water leaving bad smell on clothes
Most maytags don't heat water so even if you select hot wash it will only wash at the hot water temp available in your home, so you could end up with a cold wash
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cold water only works on rinse cylce not was
post model number in problem description
Apr 04, 2009 | Maytag Washing Machines
Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Apr 02, 2009 | Maytag Washing Machines
Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Sep 01, 2008 | Washing Machines
Maytag Neptune MAH7500AWW will not fill from hot water side
check out the hot water tap is on then check out the hot water valve for continuity (poss 27 ohms) then check for blockages in the small inline filter at the valve.
Jan 20, 2008 | Maytag Neptune MAH7500A Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
