Question about HP Office Equipment & Supplies
I have misplaced the manual. I need to insert the black color cartridge.
  • 60 Answers
You should be able to go to website of your printer and download a manual
Posted on Sep 22, 2008
My printer continues to say that my left cartridge is incorrect and my right cartridge is incorrect. I have misplaced my printer booklet.
- Make sure you are inserting the correct cartridge versions for your model. The Lexmark X5470 uses 32 or 34 black cartridge and 33 or 35 color cartridge.
- Ensure that both your cartridges have plenty of ink in them and not empty.
- You can also try to insert different known working cartridges to determine if what you're currently using is faulty or not.
- Try to remove the cartridges from your printer > close the printer cover > unplug/re-plug the printer into the power source to reset it > when the printer turns on, reinsert both cartridges.
Hope this helps.
Aug 24, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have installed a new black and color cartridge and still I have a color cartridge replace error message. What do i do?
Your color cartridge may need some cleaning. Remove the color cartridge from your printer. Then close the printer cover. Use a moistened soft cloth and gently wipe the cartridge nozzles to clean the dirts and clogs. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the color cartridge and make sure it's properly inserted and secured in the cartridge carrier. Try to print again. If error continues, try to insert a different known working color cartridge to determine if the other is faulty.
Source: How to Clean the Print Cartridge Nozzles and Contacts Manually
May 09, 2011 | Lexmark X2600 InkJet Printer
Hello'' can you tell me how to change the ink in the kodak printer?
  1. Open up the cartridge to reach the ink chamber within. For color and photo cartridges, just remove the lid with a sharp knife (insert it where the black and colored plastic meet) to find the three fill holes. On black cartridges, make a hole with a heated pin or drill on top of the cartridge where the letter "K" is.
  2. Step 2 Check the chambers in a color/photo cartridge to determine which color ink is in which chamber. Insert a different toothpick or pin into each chamber to draw out yellow, cyan or magenta ink.
  3. Step 3 Fill a plastic syringe bottle with enough ink in the color you are refilling. A black ink cartridge should need 10 to 15 milliliters. A color/photo cartridge takes 5 milliliters of each color.
  4. Step 4 Insert the syringe needle into the cartridge, sending the tip down to the bottom. The chamber contains a sponge, so you will need a small bit of force to push it in.
  5. Step 5 Inject the ink into the cartridge. Unlike other brands of cartridges, you want to saturate the sponge with ink in a Kodak cartridge. Depress the syringe plunger slowly until you can see the ink begin to surface on top of the sponge.
  6. Step 6 Wash all ink residue out of the syringe after you've refilled one shade of ink. If you intend to refill another color immediately, dry the syringe out first.
  7. Step 7 Replace the lid on a color/photo cartridge. Apply a strip of tape to the spot where you first removed the lid to secure it. You don't need to seal a hole you drilled in a black cartridge.
  8. Step 8 Leave the cartridge standing in a secure spot overnight. This helps the ink settle within the cartridge for even printing once the cartridge is back in the printer.
Apr 30, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Where do I put the replacement cartridges?? I can't see where it goes on this printer???
here is your answer this was found here in your manual if you need it heres a link with picture instructions. start on page 15
MANUAL:
Open the printer, and then press down on the print cartridge carrier levers.
Open the color cartridge foil, and then remove the cartridge from the pack.
Remove the tape from the color print cartridge, insert the cartridge in the right carrier, and then close the color
cartridge lid.
If a black print cartridge is included in the box contents, open the black cartridge foil, and then remove the
Note: You may need to purchase a black print cartridge separately.
14 Remove the tape from the black print cartridge, insert the cartridge in the left cartridge carrier, and then close
the cartridge carrier lid.
Close the printer, and then load plain paper
Mar 26, 2010 | Lexmark X4650 InkJet Printer
Trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
May 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
Displays Error Code 1203 - What is that? User Manual is lost.
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How to insert ink
you mean ink cartridges?
Remove the tape from cartridge.
Caution: Do not touch the copper-colored contacts of the cartridges. then hold on the top HP logo. Insert it (tri-color cartridge- left slot)-(Black cartridge- right slot) make sure you push the cartridges firmly until they snap into place.
see your manuals dear, you have it with your printer u bought.
Aug 02, 2008 | HP Office Equipment & Supplies
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
Thanks
MAC.
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
24 people viewed this question
Ben Johnson
