Question about Toshiba Satellite Pro A210-EZ2202X Notebook
Toshiba satellite A210-19T
Sir pls help me my laptop keeps freezing, i try to restore it to a previous date but it keeps showing error with the code 0X80070565, but if i choose safe mode it works nice and normal
it is toshiba satellite model A210-19T
  • bbakori Sep 22, 2008
    I did not add hardware to the system, all i did was uninstall the professional avast and replace it with kaspersky 2009 trial version then my computer problem started
    Problem Solver:
  • 4 Answers
Hi my name is gary and i will try to help you with your problem
first of all have you recently added any new hardware to your pc i.e graphics card ..sound card if so start up in safe mode then remove the driver using the add and remove feature in the control panel......if this was the cause of the problem it should now ok
Posted on Sep 22, 2008
  • willhay7 Sep 23, 2008
    what i would suggest is to remove the kaspersky antivirus using either the add and remove programs or the software unistall utility...once this has been done reload the professional avast and see if all works correctly again if all is working remove the asaid software reboot the laptop and see if it is still working without problems.........if working ok try to reload kaspersky hopefully this should work correctly without any problems
My Toshiba L305-S5907 wont unfreeze
Do a System Restore again but pick a restore point (date) before the troubles began.
Oct 11, 2012 | Toshiba Satellite L305-S5907 Laptop
Good day! My toshiba satellite a135 s4407 is not loading windows. When i turn it on its prompts the windows error recovery and i select start windows normaly. Then the monitor will just went blank. Please...
Turn on your Toshiba > press F8 repeatedly >>> Select SAFE MODE >>> ( if you are not sure what went wrong >>> Click yes on system restore >>> ) (it will restore yoour system to the date previously you select >>> let says 1 month earlier)
Your unit will restart automatic
If your unit keeps restart after enter the safe mode >>> Insert Windows vista CD/DVD >> boot with it
select REPAIR your system
Aug 15, 2011 | Toshiba Computers & Internet
Dear sir, my toshiba m45-s2652 has followsing problems: 1- i was trying to install windows xp sp3 and its was showing ACPI compliant problem. 2-I tried to restored original xp by dvd and now each time...
After insert the CD restart the PC and press F2 , F10 , F12 whatever is the case to change the boot order settings and select CD-ROM.Then start your installation from the CD-DRIVE.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | Toshiba Satellite M45-S2652 Notebook
Bad image error message
Upon startup, one of the F keys, usually F4 through F8, will bring up a system repair screen, with a lot of options. Pick "Restore and Backup". Then Restore your computer to an earlier date. This will keep all your files and programs, and restore your registry and drivers to an earlier date when they worked. You probably got a virus, and this will get rid of it. Good luck, and hope this helps.
Jul 08, 2010 | Toshiba Satellite P205D-S8804 Laptop
My laptop's (Toshiba Satellite A105-S361)desktop doesn't bring the desktop icons and the task bar after I loaded AVG 9 antivirus software. Why is that? Would you mind give me a solution, pls?
The desktop icons and the task bar would generally dissappear if you have a virus on the PC. However, sometimes improper software installations may cause undesired results like we have right now. Instead of trying uninstalling anything, try restoring the system to a previous point using system restore.
Oct 20, 2009 | Toshiba Satellite A105-S361: Satellite...
A blue screen came up saying something about the memory module!
oh k..
so u mean whenever u start ur computer or whenever u work on it, it shows Blue screen...
This blue screen is called BSOD Error (Blue Screen Of Death)
It occurs due to several reasons but since u specified abt memory, this might be showing you Kernal Memory Dump, i hope..
Dont need to panic, try to start up computer in safe mode & restore it to previous known date at which u didn't had that problem..
It generally occurs after installing some new softwares or drivers that conflicts with the memory module.. so try to restore ur system else try removing ur newly installed software or driver...
Hope this helped u out..
Aug 27, 2009 | Toshiba Satellite A65-S1062 Notebook
Toshiba screen press f2 for set up and f12 bios management
I guess a new software install could have caused the issue. The could be conflict between devices.
Remove all the USB devices connected to the laptop. Remove external mouse and keyboard also if any.
Try booting. If it still does not boot then restart system and keep pressing F8 to view the boot options. If you get the boot screen then choose Safe mode option and try booting in to the desktop. Once the desktop is available go to Start-> Accessories-> System Tools-> System Restore to restore your system to a previous date.
If F8 does not work then probably you can do a complete reinstall of the OS by pressing F11 or Ctrl+F11. You will lose all the data in the system using this option and the system will be restored back to its factory settings. (This option works only if the laptop has manufacturer provided OS in it)
else you need to contact Toshiba tech support for any hardware related issues
Hope it helps !
Good Luck !
Jul 02, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Corona\start-bg.bmp error on toshiba sat a200
have you installed any other software recently? you might try system restore and if that didnt work,try uninstalling and reinstalling your webcam driver
Jun 25, 2008 | Toshiba Satellite A135-S2276 Notebook
I've been using two monitors for about a year. Today, I can't get my Satellite P205-S6267 to recognize the second monitor.
If you actively set Restore Points.. You can attempt to fix by restoring to a previous date..
Also Check Device Manager to See if any errors are in there..
May 20, 2008 | Toshiba Satellite P205-S6287 Notebook PC
My toshiba laptop keeps freezing unexpectadly
Whats causing my Toshiba Satellite U205-S5002 laptop to keep freezing? Need assistance on how to troubleshoot the problem.
Oct 24, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite Pro A210-EZ2202X Notebook Logo
422 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
