Question about Fossil Watches
I bought a fossil FX2008 Palm OS Wristwatch PDA. the problem is no matter how long i charge the watch, when i unplug the charger, the watch turns off. and can not turns on again.
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
escapement
  • 2334 Answers
SOURCE: battery for fossil jr8192
Batttery is 626 or 621. The differnce is the thickness- 626 is 0.05mm thicker than 621. Both of them will fit your watch. Ask any watch battery trader for 626 or 621 watch battery and they will know what you are asking for.
Do not forget to rate, please.
Posted on Feb 28, 2009
escapement
  • 2334 Answers
SOURCE: My Fossil Blue AM-3662 wristwatch requires repair.
You do not need to send your watch to FOSSIL for repairs. Just find your nearest watch repair shop and ask watchmaker to replace the coil. It will save money as well.
Posted on Jan 27, 2010
Testimonial: "Thank you for your prompt reply, I will contact my local watch repairers tomorrow."
escapement
  • 2334 Answers
SOURCE: I found a fossil fs2760 arkitect wristwatch, not
I'd advise to go and see watchmaker. He/she will have proper tools and batteries to fit.
Posted on Jul 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: fossil wristwatch: hour and minute hand not in sync
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
I lost the Wrist Net power supply but I do have the charger base. What voltage is the power supply?
Wow, I haven't used my SPOT watch in years--but I found it!
The charging base for my Abacus AU4000 uses an adapter rated at 12 volts, .11 amps, center positive. I believe that all the charging cradles for the Abacus Wrist Net series watches were the same--the different model numbers referred to different case and band options.
Good luck, and don't hesitate to follow up if you have any additional questions.
May 26, 2011 | Fossil Abacus AU4002 wristwatch
My husband got a fossil watch for a 15 year service from his place of employment, one of the stems (pin) came out of the band and I am trying to locate one to fix the band. thanks
the best thing to do is the next time you go to the mall take it and ask one of the people in those little watch booths if they have one that'd fit. they shouldn't even charge you.
Aug 04, 2010 | Fossil AU4003 Wristwatch
My Fossil FS4283 had been working fine since the time I bought it in 1997. It stopped working suddenly a couple of days ago and no matter what I do doesn't start back. It doesn't have a battery and charges...
mcdevito75 here, Sounds like the chargeing system has gone bad in your Fossil watch, Best Bet look for a small watch repair shop in your area, have them take a look at thr watch.
Jul 02, 2010 | Watches
Fossil links
Link
You can try contacting the Fossil's Authorized Dealer thru above link to further assist you.
Thank you.
Dec 30, 2009 | Fossil AU4003 Wristwatch
I purchased a abacus wrist net on line with msn direct , and my battery isn't charging with my charger.
Your issue may not be that the watch is not recharging, it may just need to be reset. This will work on most, but not all of the abacus watches. You need to press all but the top left button at the same time. Do this 20x if successful, your watch will magically power up. I have this issue from time to time, usually right after a static shock. Hope this helps!
Dec 15, 2009 | Fossil Abacus AU4002 wristwatch
Battery for fossil jr8192
Feb 28, 2009 | Fossil Watches
How to adjust band
My best suggestion to you is to take it to a Fossil store (they will do it for free!), or go to a jewelry or department store (Dillards, Foleys) to get it sized right.
The problem with doing it yourself is if you do not have the correct tools you can scratch the watch or bend the pins easilly. Especially with the black band like you have.
If you go to a jewelry repair shop they will charge you. I have seen them charge anywhere from $2.00 to $15.00. Unlike Fossil or a few other big department stores.
Dec 12, 2007 | Fossil AU4003 Wristwatch
Fossil watch battery
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Watches Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
