Says printer is off line - Computers & Internet
  • 32 Answers
Try Going To Canon MP210 Series PC Printing Guide. Look Under Basic Print .Then Click On Printing With Easy Setup. That Takes You Step By Step On Setup ,,Shows All Your Needs...From Connecting The Printer To The Network To Checking The Print Head Nozzles And So On. All Your Needs Should Be Right Here. Hope This Helps You.
Posted on Sep 21, 2008
Printer off line
go to printer folder then double click printer then check there is right tickmark on use printer offline just remove it and check
Jul 21, 2013 | HP DeskJet F380 All-In-One Printer
Printer kicks me off internet
Try it:1..Telephone line straight away to system modem line in socket.. from modem line out socket to printer line in socket(marked as box symbol)dont insert tele phone line in phone symbol socket.. 2..Telephone line straight away to printer line in socket.. from extension socket(marked as phone symbol) to system modem line in socket...Note:dont split telephone line like branch.. Describe this issue with telephone operator because of both fax & internet will work in digital signals, result conflict may happen..
Jan 31, 2012 | HP Laserjet CM2320nf All-In-One Color...
Unable to receive fax
Condition 1 - Whn you dont have DSL line
The telephone line coming from the out is connected to Line 1 on the back of the printer and then going to any other device.
Condition 2 - If you have DSL line
Make sure that the line is coming in the Line 1 of the printer from ADSL filter
Jan 04, 2011 | HP J3680 Officejet All In One Printer
Printer is off-line-how do I get it on-line?
OK.------------ 1) First check whether printer power is turned Off or is On.If its off then turn it On.But iof its on. 2) Then check the printer to pc connection.The connection between printer and pc is called USB port connection.And this is connected via USB wire.So check this connection properly,to the printer side as well as pc side.If both the options 1 and 2 checked ok.Then try this procedure to turn printer on line. ------ The procedure is as follows:--- 1) Click the start option at the lower left corner of the task-bar. 2) Then click "settings" option. 3) Then click the printer & faxes option/. 4) After you click the printer & faxes option, a page will get open.On that page you will see your printer Icon. 5) Right click on that printer icon.I repeat, right click on that printer icon. 6) As you right click the printer icon option,some more options will get open.In that options you will see the "printer on line" option.Just click on that option. 7) The printer will get online. 8) If you re-click on that option another time,the printer will get off line again. -------------------- This is the basic procedure to turn printer online from a offline condition. ----------- But in case this all the three options are not helping then the last option to turn printer on line from off line is to reinstall the printer drivers. --------- For any other further query,please keep updated.Thanks.
Oct 12, 2010 | HP Deskjet F2180 All-In-One InkJet Printer
Jobs go to the print que, but nothing prints,
There are a few possible problems:
1. The printer is set to off-line. Go to start, select printers and faxes, then double clip on the printer icon, check the options under the printer tab. See if it is set to off-line, uncheck the option.
2. The printer is not connected? Too obvious, but check it.
3. The printer is set to off-line. Check the printer buttons.
4. There is no paper in the printer or the paper tray is not properly set.
5. There is some other problem which generally causes the printer to go off line.
Jan 28, 2010 | HP LaserJet 1020 Printer
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
How do you set up fax phone on the HP officejet 6215
hi you really have a very good choice of printers is one of the best printers from hp
inorder to set fax on ur printer you should first be sure what type of telephone line you are using
there are 2 type of line 1 dedicated -> that is directly attached for fax and has no other telephone or TAM connected if you have this line you can directly attach the phone line on the printer line 1
the other type of line is shared that means you use the same line for phone and fax in this the connection should be as :- telephone line from wall jack to the printer line 1 then from printer ext port to telephone answering machine (if any ) then from answering machine to telephone (if u have a dsl line that means u use phone and internet from the telephone line then there will be 2 lines comming out of the splitter 1 to router and other to telephone here follow the shared line connection mentioned above using the line that goes to the telephone )
now power on the printer and press the setup button (menu) now navigate to basic fax set up press ok and then go to rings to answer it should be 4 rings now go back and go to advance fax setting and then to distintive ring (DRP) select all rings and press ok now run fax test if it passes then ur fax is set up try sending fax now hope this will help you
Jul 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Some lines are blurred, Some lines are printed larger, Some lines
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Need to set up printer on line
click the start icon on the left side corner on your pc---then click printer and faxes----then right click the printer icon which you are using -----then in that the ON line / OFF line option will come .do it on line by clicking the on line option.
thanks.
Sep 18, 2008 | Lexmark Office Equipment & Supplies
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
