Question about Performance Teknique ICBM-892 Car Audio Amplifier
Performance teknique icbm 892 1200 watt amp
What size and brand of subwoofers do you recommend.
  • 631 Answers
DD, JL and pioneer in that order. I don't recommend any particular size but 12s are a good compromise.
Posted on Sep 22, 2008
Whats the RMS Watts on a Performance Teknique ICBM 5910 I know it has 1500w peak but I'd like to know the rms watts on the subwoofer
Personally, I would not put more than 500 RMS total to that sub. 300-400 RMS is more like it.
Jan 05, 2014 | Car Audio & Video
Need box dimensions for 12 inch performance technique icbm-5912 car subwoofer
I have the same sub on the "digital" amp from the same company.
I used the 1.75 ported box from my jl 12w3v3-4 and it sounds great. I am not sure on the correct box size but the box for the 12w3 sounds great. I tried emailing performance and the email was wrong.
Feb 26, 2012 | Performance Teknique ICBM-5912 Car...
I have 2 kicker cvr 15 4ohm dvcs and a performance teknique ICBM power 4000 watt 1ohm stable amp when I hook up my speakers 1 ohm it kicks my amp into protect when I wire it at 4 ohms it works fine how do...
Are your subwoofers wired in series or parallel? Check your connections, if everything is ok, the problem is with your amplifier. It might have a blown capacitor inside or its not really a 1ohm stable amplifier. Have it repaired if thats the case.
Apr 11, 2011 | Performance Teknique Car Audio & Video
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    Dont know how to connect daul voice coil on a icbm-5612 performance teknique.
    If you want a 2 ohm total load..wire it from the amp positive(red) to the first coil positive(red) and then to second positive(red). Amp negative(black) to first coil negative(black) and then to second negative(black). This will give you a 2 ohm total load on the amp.
    Apr 21, 2010 | Performance Teknique ICBM-6112 12" 4 Ohm...
    WHAT KIND OF AMP SHOULD I USE ON SOME ICBM-5612
    You can use any type of amp as long it can drive at least 1000 watts and it 2 ohm, 4 ohm or 8 ohm stable.Here is the specs on the woofer:
    • 12" High Performance Subwoofer
    • Rubber Seal Gasket
    • High Temperature 2" 4 Layer Voice Coil
    • Air Vented Aluminum Fomer
    • Dual Voice Coil ( 4 ohm + 4 ohm)
    • Large Foam Edge Surround
    • Bumped Plated For Maximum Excursion
    • Excellent For Sealed and Bandpass Enclosures
    • 70 Oz Magnet Structure
    • 1000 Watts Max
    • Frequency Response: 25Hz-800 Hz
    • 2 Ohm / 4 Ohm/ 8 Ohm Operation
    • Screw Block Terminal
    Also check this website for how to wire it to 2, 4 or 8 ohms: http://www.bcae1.com/spkrmlti.htm
    Dec 26, 2009 | Performance Teknique ICBM-5612 Car...
    I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
    Hello perezmagdiel,
    That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
    Hope this helps.
    Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
    Performance Teknique ICBM-9550 Amp Problem.
    one of the power transistor of your unit shorted check use a tester
    Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
    Performance Teknique ICBM-892 Car Audio Amplifier Logo
    556 people viewed this question
    Top Performance Teknique Car Audio & Video Experts
    hoyzee1
    Joe Alexander
    Joe Alexander
    George Nalley
    Level 1 Expert
    Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
